Use more than 1. The design i have in the books will use 4.
dave
Any early SketchUp or CAD teasers?
Need?
Bob
Bob,
If you are referring to the need of visuals - it is simply a form of inspiration / ideas on what can be done and also can get more discussions going. I myself do not have the room size to utilize such a speaker system.
Bob,
If you are referring to the need of visuals - it is simply a form of inspiration / ideas on what can be done and also can get more discussions going. I myself do not have the room size to utilize such a speaker system.![]()
I was referring to post #20. I should have quoted if.
Bob
I was thinking of these: http://www.diyaudio.com/forums/css/176790-el166-mtm-ml-tl.html
They played real deep, real loud, and did it cleanly. Hopefully the new woofers will have a similar output.
jeff
Jeff- since Mark is still putting the Alpair label on these, I'd be quite surprised if they didn't out-finesse the EL166- and Dave's thought experiment about 4 in one box -apparently not yet committed to publishable drawings- has me worried![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Not another faceted box, please
- I can hardly remember how I finally managed the first pair.
Dave's thought experiment about 4 in one box -apparently not yet committed to publishable drawings- has me worried![]()
You better install an electric hoist above you work area.
jeff
Facet should be easier on this one. Remeber the brain-spurt while waiting to see the Jennys?
dave
dave
that's embarrassing - nope
I think pre-ordering can be by through Adam - I don't have his direct e-mail, but you can probably get him via the info@ contact
info@madisound.com
They're either waiting final clearance / customs etc to set firm selling prices and update the website, or it's just the dog days of summer .
info@madisound.com
Adam Johnson <adam@madisound.com>
dave
My initial thoughts...
The 7 definitely sealed, not sure whether the woof's should be in the same or separate cabinets.
Very loosely modelled from my http://www.diyaudio.com/forums/markaudio/254280-curved-pensil-inspired-alpair-10-3-prototypes-build-log.html And so CNC ribs, although my new bookshelf designs are using CNC'd plywood stacked up, with solid front and over-veneered, would love rosewood, but finding solid is quite tricky.
So no, no efficient production method, Once our CNC is back together I will get the small bookshelf design made and see if the plan works...
- More Vendors...
- Planet 10 hifi
- Alpair 7P & Alpair 12PW combination.
