Do any of ya'll know where I can find some plans for an altec 1005b horn? Or any altec multicell horn?
Thanks,
Nick
Thanks,
Nick
I wonder if the plans ever left the shop? I own a pair, if you need measurements.
There is an old thread here about building multi-cell horns from wood.
Hi Pain, I actually found that thread and sent Petter an email. I'm thinking I might try and make one with a conical design first for the sake of simplicity.
Nick
Nick
Sure Nick, let me know if you need any info. I think making them out of thick card or matteboard might be easiest, then coat the walls with wax or something if needed.
EDIT: 6.25x6 inches each. About 17" back to where they join together. Then the throat behind that.
1/8 inch seems more reasonable. You need it then where they all join.
Didn't even know there was 1/8 plywood. Not really much there for a miter joint.
Where the cells join together is very important. You'll have a hard time with anything as thick as 1/4". 1/8" can be found at Lowes or Home Depot.
I noticed in the other multicell horn how he sanded them down at the ends.
The first time I build these will basically be a practice run for assemble. So I'll find out what works and what doesn't. That's why I'm just doing conical instead of exponential.
We will see how it goes.
Thanks,
Nick
Thanks,
Nick
Cool. I suggest matte board or similar. Easy to work with, stiff and thin. I'll bet you that a square horn is going to be easier than conical. I wanted to do hexagonal (honey comb), but never tried.
Let us know how it goes!
Hello, I know this is an old thread but I am going to pull on it anyway. I am looking at building my own copy of the 1005B Altec horn, You mentioned that you had one. I would LOVE to get some dimensional information from you on those if you still have them.I wonder if the plans ever left the shop? I own a pair, if you need measurements.
Can you help?
Steve
- Altec 1005B horn plans
