Thanks guys, but the work is only half done.
As for now I have used pink insulation on the bottom, top, one side and whole back. Is this a good starting point? It does sound better the open baffles already but is there a way to conduct some home experiments to get as much of the performance as possible?
Cabinet-damping
I have some felt and fill ordered last night, same as one over here.... 8mm felt and 30mm polyester
Cabinet-damping
Great work! FYI: if you’re in Canada, Rona used to sell nice white fibreglass in rolls. Not cheap, but great to work with for speakers.
Will check that. Thx
I still think 604's scream for bi-amping!
That’s why I have left my crossovers out. Two sets of terminals per box is what I have now. Not that I need bi-amping right now but may try one day...
Of COURSE, you need it right now!!🙂Not that I need bi-amping right now.......
radarek, didn't look like the enclosure had much bracing. The panels are pretty large and BB sings like a canary. Bracing will help tighten up the sound.
Some pictures of bracing
That is better than what it looked like through the holes in the other pic's. You had the drivers installed. Is it "good enough"? I just mentioned it because adding additional bracing now is easier to do.
I’m happy the way they are build. Can’t see me doing any structural changes without serious listening to them first. Plus set up and room treatment will be my priority number one. I spaced them out a bit, maybe another foot, that helped bass a lot. Centre of driver is now 33” from side wall and 60” from back wall. Center to center is 86”. Yesterday I had them playing for 8 hours and couldn’t stop listening and smiling... looking forward for the tube set so I can finally fire my SET amp.
Room is 12.5 feet wide and 30 feet long. Ceiling absorption tiles with 7” insulation behind. 7’2” to the ceiling and 8’4” to the deck upstairs... 3 walls are single layer of drywall on 24” centre 2*4... wooden wall is 16” on centre + drywall + 1” reclaimed wood. Potential for sound is there, needs sone serious room treatment now...
Very nice indeed! Those are big, that's good.
As for damping material, my experience with speakers like that would rate them this way for sound quality and effectiveness.
I know you'll enjoy them.
- Pure wool felt (soft)
- Bonded Logic denim insulation
- Rockwool panels
- Fiberglass panels
- Fiberglass loose.
OK, so it exists. Still, it's not like you to use big words like that. Just sayin'
Ha ... I had to check it too... similar to soundproofcow.com
Blame your buddy over on Vancouver Island. He turned me on to it. 😛OK, so it exists. Still, it's not like you to use big words like that. Just sayin'
- Altec 604 build
