Alternative oamp for ne5532
I've bought the FX-502SPRO, a very nice and surprising amplifier.
I understand I can replace the ne5532 with another model and to achieve a different sound.
I'm looking for another OAMP with a warmer sound and more weight in the low frequency.
Any recommendation?
Any recommendation?
I recommend you retain the '5532, it is a superb and greatly under rated opamp. If you replace it for a different sound you are simply wasting your money. An opamp swap WILL NOT change the sound of your circuit unless the replacement is flawed.
The NE5532A is a fine opamp. If you replace it with something else you may introduce instabilities due to the way the circuit is designed. This will ruin your sonic experience. Unless you understand the circuit and its requirements this is thoroughly discouraged. But if you did then you wouldn't have had to ask this question in the first place.
Remember, the content you listen to right now has gone through scores of NE5532 opamps. Changing one of them will not make one iota of difference.
Spot on, on all counts.
Any recommendation?
Hi
the FX-502spro is discussed here:
TPA3250 somebody is listening?
the NE5532 is a fine opamp but at the chinese board in the fx502spro there are fake opamps. so any change the a genuine op amp is better then the fake ones.
chris
Reactions: ASPERGER67
