Anyone tried a Dell LCD?
thanks
thanks a ton kickstarter. One more question. Has anyone ever taken this or the LM151X2 apart? Do you know what size flex cables are required for extending both boards. I would take it apart myself but im actually using it as a second monitor right now while i order my parts. Thanks.
{thanks Post #4
Well I dont know anymore how long these cables are, this type monitor is out of production now, and almost a year ago out of warranty also.
I work at a repair centre of dell so i have had many of this type in my hands.
Oh now occurred to me there are two more type panels used in this monitor so i am not sure what type you do having in your monitor.
Toshiba LTM15C430 and
Sharp LQ150X1DG12.
I do also not know if these are easily stripable...
succes
Dell 2001FP
Hi Kickstarter,
Loke33 i don't have any knowledge of the dell 15". But was wondering
if kickstarter has any information about another monitor, the
Dell 2001FP.
It has an LG lcd panel inside, have the number, but not handy at the moment.
I have a couple of these and they are very nice, but i hate to pry or mark
up the case to take them apart, no screws. Also, have fresnels to fit.
Kickstarter, is there a way to find out if this has flex cable problems,
or does Dell service have blow apart repair diagrams of the case and
panel? Tried to email you, but you have that function turned off.
Tony
captains log
Captains log, Supplemental,
In a few weeks, I, will be traveling, to the, inner depths of, the dell 532OU, to boldly go where, so i think, no one has gone before. Thank you, kickstarter, for the, information, about, this panel. Anyone else, who, may be able to, give any, information, about, this panel, please feel free to, post, on this, thread.
Thats my best captain kick impression in text, sorry if it was annoying but i felt it appropriate.
Also, good question Mr. Dean. Any help from dell repair is going to be good help.
TonyDean,
I couldnt believe my eyes.....are you really going to use a 2001FP as a projector???
This is a brand new monitor 20 inch size with composite and s video input. It is really a beauty model.
It cost 899 euros !! you better buy a professional DLP beamer wich can give better results then you 2001fp as a beamer.
I dont think there are no fresnel's of 20 inch size!!
A case would be big as a television, even bigger !
This is a brand new model ,former model was 2000FP made by Acer.
I havent yet have this model in my hands maube son when the first one goes defective.
There has a korean or chinese dude come over here to instruct us about this model.
If you really want this you have to wait for monday ,then I ll look for this model and thake some apart.(take pictures perhaps)
But the most modern panels are easy to strip.
Any way I do not recommed use this monitor for a PJ project because of the big size.
Kickstarter
TonyDean
One question from you i have not answered and that is about opening case.
Well I think that is the same way of most Dell models with no screws;
First remove the stand.
Go stand behind the monitor. put your fingers at the front bezzel and your thumb on the backcover.
Push the front outwards and the back to the middle of the screen.
Then you will hear a click or crack and the lips inside come loose.
Then is it easy to remove the front (lcd and chassis are mounted in rearcover).
Take Caution about a small part (pcb) where the front buttons is located and a small cable can be disconnected.
Then see for your selves what you do.
Loke33, go boldly go where i have been before ...and see it is a easy monitor to open.(this one have screws !)
When you take out Power module out the swivel (stand) watch out for a metalic part (heatsink) there a dangerous voltages even the power is switches off...or you will beamed out temporaraly of the reality...(or something)
Go live long and prosper, Kickstarter
Kickstarter,
Yes, i would like to use a 2001fp, if with will strip well. I have two
of these, killer monitor. LG panel, the only 16ms 20" thats true 24 bit
not dithered i believe. I use one for a tv the other for computer use.
i'm kind of a nut with this diy thing.
here you can pick them up here for a little over $700. there is no way your
going to find an inexpensive uxga 1600x1200 beamer. they tend to run many
thousands of dollars. I already have fresnel lenses that will cover the
complete screen. size doesn't matter that much to me. i have been building
15" lcd in to coffee tables, end tables, etc. the 20" Dell would fit into
my 15" table projector no problem at all.
actually the price is quite cheap compared to the alternatives. i have a
couple sgi 1600's that i just started to make into a projector today.
they are 1600x1024 wide 17". i'm mounting them in solid hardwood
chests, so they will look better in the living room.
If you have access to dell monitor breakdown specs, service data, that
would be fantastic. the case work on these, and the manufacture has
changed from the 2000fp.
Feel free to drop me an email, and i can explain further what i'm
looking for.
sincerely, tony dean
picture of my dell monitor
Kickstarter
last pic. as far as i got tonight on this project. mounted the
17" lcd as the associated boards.
anyhow, would be fun to try a 20" monitor. let me know
if you can dig up any info. thanks, tony
The_Mazta
"spend 900Euros on buyin a monitor to waste on a projector, thats plain stupid, if your gonna spend that much, just buy a projector, it aint diy when it gets to that stage,"
i don't think there is any reason to call my idea stupid.
especially since you are so clearly misinformed on price/performance
level of projectors. you can't just go out and buy a projector like that
for less than the price of a nice car.
clearly, building a uxga projector for $1100 would be a big bang for
the buck, for me and especially those that don't have a spare
$30,000.
and whats not diy about that. the fact that it might may cost $1,100?
i'm trying to build quality 15", 17", and if possible a 20" projector.
and i enjoy building things, thats diy to me.
man, what ever happened to constructive posts. tony
