My first question is: Why no one gets excited about BC550/560? Their specs look pretty good, no one says bad things about them, but no one raves either. The only reference I came across was "give the flat Earth sound". I really do not know what that means. I would appreciate if someone gives me an insight into this statement.
My second question is: Is there anything better from new stock offerings? I usually shop Mouser/Digikey.
Thanks in advance.
Best
P.S. Looking for high hfe types - 500+
Thanks in advance.
Best
The BC550C and BC560C are listed as "Active" status at the ON Semiconductor web site. As with all through-hole parts, future availability is uncertain but I would bet that either they are in current production, or there is at least a decade's worth of stock sitting in a warehouse someplace. The BC850/BC860 are essentially the same part in a SOT-23 surface-mount package, and I haven't heard any rumors that they will be discontinued any time soon.
The BC54x/BC55x have been favorite parts for general audio applications for decades. I suspect they will perform "good", to "very good", in 99% of audio applications where their Ic, Vce, and Pd ratings fit the circuit's operating envelope. To ask for "anything better" is like asking, "My wife and I have been making love every morning for the last 30 years. Is there anything better we should be doing?". You need to be more specific about where things fall short. Do you want higher operating voltage? Lower noise? More collector current? Greater bandwidth? Etc, etc.
As for the "flat Earth sound" comment, I don't have the foggiest idea of what this is talking about. Go back to the source and see if the originator can point you toward a part that provides, e.g., a "tetrahedral Earth sound" so you can compare.
Dale
Dale
Hi Dale,. You need to be more specific about where things fall short. Do you want higher operating voltage? Lower noise? More collector current? Greater bandwidth? Etc, etc.
Dale
Thank you for your reply.
When I asked the question if there are better transistors available, I had in mind the voltage capabilities of the BC550/560.
It is a different question if anyone could tell me what I could use for differential pairs i.e. min 80V Vceo and hfe of 500+. The "go to" KSC1845UBU is obsolete now according to Mouser/Digikey.
Best
BC550/560 seem to be rather undistinguished transistors. 50 Vceo, hfe 270 available in C, siemens has no noise spec.
I've blown up some 2n3904, so I started using MPS8099 npn MPSA56 pnp with 80 v Vceo. Not exactly complimentary, but those are the ones newark stocked for $7 a hundred or less. I got the end of ON semi stock. Gain seemed >300, I had to employ feedback to keep them in the middle of the rail. Noise was fine, not noticeable in my AX6 front end. With the gains that high, I was able to jack up input impedance over 100k to make compatible with my 12AX7 output preamp. These also worked fine in my PV-1.3k in place of blown up MPS6531/6533 VI limiters working off 16 v supply.
Really these BC numbers, phillips is not stocked here, they had noise specs & premium features but the fairchild stock you can actually buy does not.
If the rails go above 70 I've stocked MPSA42/92. For higher idle currents that stress the heat waste ability (predrivers) I've got 100 MPSW56 but no 1 W compliment seems to be available. Trying 2n5682 in TO 39 from multicomp but thermal resistance is only 175 deg/w versus 125 for the MPSW56. TO126 devices don't fit.
Thanks for the replies so far. At this point I am only interested in refurbishing the three receivers I have. I am looking for substitutions of the following components:
2SA872 (E)
2SA844 (E)
2SC1344 (E)
2SC1345 (E)
2SC1345 (F)
2SC1400 (UA)
My idea was to use BC550C/560C for everything but the last device. I have no clue what the modern equivalent of 2SC1400 (UA) is.
Is there anything better that I could use in place of the above devices and what would the modern equivalent of 2SC1400 (UA) be?
Thanks in advance.
2SA872 (E)
2SA844 (E)
2SC1344 (E)
2SC1345 (E)
2SC1345 (F)
2SC1400 (UA)
Thanks in advance.
BC550/560 are the best for audio (very low noise).
Choice depends on design priorities of hfe vs Rbb' vs Cob and the type of application circuit. Examples in BC types choice thinking like:
http://www.diyaudio.com/forums/anal...g3-preamp-line-headphone-272.html#post5357762
http://www.diyaudio.com/forums/anal...g3-preamp-line-headphone-291.html#post5395983
However, they have a disadvantage. They are not usable in power amplifiers, since not voltage resistant at 50V+
Too general ! There are places in power amplifiers where they can be used !
Thank you for the reply. They would be used in the preamp/phono stages and in only one power amp. That particular receiver has rail voltage of 30V, I think I am safe there.
Cascoding techniques, or building completely balanced designs helps...In 1 out of 10 places.
My design decisions are based on noise and THD and not on transistor types.
Funny you are stating this....given some of your older statements.
No one can hear the difference between 0.1% and 0.0001%. And if it is, then it is imagination.
- Design & Build
- Parts
- BC550/560
