I bought some C-grade (highest beta) BC550's and BC560's from Rochester. The price was extremely low, BUT Rochester has a $250 minimum per line-item. I swallowed hard and bought $250 worth of BC550C's and another $250 worth of BC560C's. I'm now set for a good many months.
_
_
start working on this one...
By inspection: horrible noisy.
Update:
Both Mouser nor Digikey list BC560s as obsolete and neither has stock as far as I can tell.
Rochester has plenty, in a variety of grades, but the min buy is $250 (~2000 pcs) for the most expensive (BC560CG by OnSemi)
Anyone interesting in splitting an order with me?
Kind regards,
Drew
Kind regards,
Drew
Some enterprising person needs to make micro-breakout boards for a couple of BC850 or BC860's - connected with emitter resistors a pair of the SOT23's will have comparable dissipation rating and noise performance I reckon.
Farnell quote BC560 as no longer manufactured, as is the BC179, but the NPN ones (BC550's and BC109C's) are available (109C is "best seller")...
I was lucky enough to foresee this ahead of time -- and I bought 1000 of each so I'd have plenty of BC550-560 parts to mess around with, enough for the rest of my life.
I'm glad I did.
Maybe you, dear reader, might want to imagine the delisting of your favorite through hole devices ... and then immediately buy a lifetime supply now. I suspect you'll be glad you did.
I'm glad I did.
The side-by-side comparison feature of DigiKey's "Parametric Search" may be a useful research tool for you, when you seek as-good-or-better parts from other manufacturers.Doesn't ZTX have any equivalent to the BC550/560?
Fairchild/OnSemi 2N5401s are starting to dry up too....
Four hundred eleven thousand in stock at DigiKey ... in the SOT23-3 surface mount package. Draw your own conclusions.
I was just checking the Art of electronics table on Va and saw Mark's topic too. Really cool findings! Measuring the Early voltage "VA" of some PNPs at 8mAThey haven't dissapeared, they've moved to SMT packages. BC850 = BC550, BC860 = BC560
- Design & Build
- Parts
- BC550/560
