Jan has made the charts available on volumes | Linear Audio -scroll down to the bottom of the downloads page.
He has pulled the plug years ago from his website."It's dead, Jim." -- Leonard McCoy, MD
_
He explains this in column 5, lines 60-64 of the issued patent
US8294440B2 - Voltage regulator using depletion mode pass driver and boot-strapped, input isolated floating reference
- Google Patents
- Google Patents
Close. Try:
Downloads | Linear Audio
... and search for: 'Color graphs for Jack Walton's regulator article in Vol 4', almost at the end.
- Google Patents
It's hard to pin point this. I have only two columns in 15 pages? Can you copy the text so I can find it?
It's easier than you think. Just do three things:
1. Open the attached pdf. It is only 1/16th of the patent.
2. Locate column 5. The index numbers are at the top of the columns.
3. Locate line 60. The line numbers are in the middle "spine" between the left column and the right column.
Then read lines 60 thru 64.
- Power Supplies
- Belleson Superpower regulator, here's the schematic
