Newegg.com - SanDisk Sansa Clip+ 1.0" Red 4GB MP3 Player
With the coupon (ending this month), the player is $28 shipped, which seems to be a good value for this technology.
Will it do?
Will it do?
Lovely features and exploring, but ultimately a failure.
In the first three hours of trying to get this device to work, but it only said "Music" on the screen with a flashing blue color, I finally discovered a powerfully adhesive and sturdy black sticker with the word "Music" in translucent, was atop the real screen. After prying off that nearly secret sticker, the Sansa Clip+ became somewhat easier to use.
Like anything with engineering, they decided to randomize ordinary language, and MSC mode vaguely refers to whether or not the device will act like a usb disk drive, and mountpoint vaguely refers to drive letter. Although the menu is gigantic and much like pre-1993 web surfing, it isn't difficult to guess your way through it.
The ">>" next button actually works but the means of using it is never mentioned. To make it work, one goes to the "Music" folder and then makes subfolders, such as Rock, Pop, Classical, WW2, Oldies, Country, Jazz, Relax, etc. . . or perhaps one could sort by activity, like Workout, Dishes, Road Trip, etc. . . But, my point is that when more than one file is in a given folder, the ">>" next button will work. Otherwise not.
Generally, this device is reminiscent of a half-power, half-size Iriver. The Sansa Clip+, like most modern sources, including computers, has omitted the output buffer, which could have assured a level response, tame mids and plentiful bass. . . but not if it is missing, as is typical for a modern source. Thus you do need the RockBox and a severe workout with the EQ (advanced EQ is most useful).
Both the addition and the omission cost about 3 hours of time apiece.
The Rockbox software also took about 2 hours to figure out, but does have extensive online documentation.
Without either the voltage amp strength or an output buffer, the jammin out is in short supply. Attempting this results in audio quality similar to setting the computer to max, aka, the louder the worse. That's just a typical modern caveat.
Bass vs midrange management: They included a crossfeed+stereo width system which is quite good, and of course that feature is the easy way for tamer mids without the distortion of aggressively set EQ. I set stereo width to 140, crossfeed to custom, and you'll have to work out the direct (center) versus cross (stereo) on your own. This is a great thing because you can mix instead of muffle.
The included compressor is the typical digital type that causes clipping on most settings; however, one can set it as a transparent limiter this way: Shut off the make-up gain feature, set the threshold to just 3db, the knee to hard and set the ratio to 6:1 and set the release time to 700ms. Now, it will "wait until the last minute" and actually reduce clipping.
The EQ "Precut" can be set 3db less than the EQ bass boost, thus effectively using the compressor if the volume happens to be all the way to the top, but not otherwise using the compressor at all.
The EQ advanced settings can be with the low shelf filter to 90hz and the Q factor at 0.6. The gain on this spot maxes about 14.5, meaning that the precut setting is then 11.5 if you used the compressor or 14.5 if you didn't. The AF section doesn't have the typical 2nd order harmonic distortion--it is non-boomy, and therefore I ended up increasing the 200hz EQ slider to get some bass slam--that's how other MP3 players get successful bass power, and this player is not different in that regard.
Treble management: Set the advanced EQ high shelf filter to 16k instead of the factory 12k setting, turn on the dithering, disable the make-up gain, and set the precut enough to dodge the clipping.
Although, apparently the analog engineers did not sleep though class, the big workout with the EQ could have been averted with either parallel op-amp output or output buffer. Even though I'm complaining about the omission, it is fairly obvious that the Sansa Clip+ has Less screwups than a typical modern source device.
The radio is pretty good, however, displaying the db strength meter causes a "tick-tick-tick" sound that will go away, if one, inconveniently, turns on the menu so that the meter is disengaged and the radio continues to play without that noise. Despite this small inconvenience, the radio is impressive. The EQ works with the radio! YAY!
For MP3 playback, it is quite coarse, so one would want to turn on the "dithering" feature to make the distortion less audible, and even then it is not overtly talented at MP3. However, Flac playback is quite good.
The Sansa Clip+ can be set to "Car Adapter Mode" and run from a mini-usb cord and 5v linear regulator. This method: 12v unreg > 9v reg > 5v reg or a similar approach, simulates clean everlasting battery power.
Like the PC onboard sound chip, one could add a buffer or a buffered preamp or a buffered preamp with an output buffer, as any of those options do happen to inspire some bass slam so that EQ abuse is unnecessary.
SO, it can be used as a home or non-portable source device. It can also be used with projects such as Boominator, Halfinator, Qubinator and the like, if one alters the power amp gain, severely, so that the Sansa Clip+ does not have to run at max. This prospect is barely within the gain capacity of the TA2020 (4-speaker units) and TA2021 (2-speaker units) for gain versus audio quality. Yes, it does work out.
Caveat: What it doesn't do is jam out with headphones more successfully than any other MP3 player--Due to severe lack of power, the nicely adjustable tone is defeated by clipping, rendering the many features useless, and setting the precut/gain low enough to avoid clipping results in a "non-rocking" amount of output power. This is really a "bait and switch" like experience. To put it bluntly, for loud replay with headphones, this device is a fail, unless one adds an additional box that could drive headphones. And for MP3 playback, the decoding is of mediocre quality that is considerably worsened by any attempt to play it loud when direct driving headphones. But, for many other tasks, including relaxing with headphones, the Sansa Clip+ can do well. . . so, it succeeds at almost anything other than what the device is made for. And, therefore, this purchase incurs a redo.
Although it certainly doesn't fill the primary job of an mp3 player, I may keep it for its many other charms.
Does anyone have a suggestion for something with more substantial power and either RockBox compatibility or a multi-band adjustable onboard eq? As seen with the Sansa Clip+, adjustability is pointless without the power (and decoding quality) to support it. So, I would like to purchase something both adjustable and significant.
Dude, I thought you would like Rockbox!
Isn't the digital cross-feed awesome! I almost pooped my pants going through the Rockbox manual: just cool feature after cool feature!
Imagine what it could do on a player with drive capabilities! 😎 Do you have any of the other 'stable port' players?
Apple: iPod 1g through 5.5g, iPod Mini, iPod Nano 1g
Archos: Jukebox 5000, 6000, Studio, Recorder, FM Recorder, Recorder V2 and Ondio
Cowon: iAudio X5, X5V, X5L, M5, M5L, M3 and M3L
iriver: iHP100 series, H100 series, H300 series and H10 series
MPIO: HD300
Packard Bell: Vibe 500
SanDisk: Sansa c200, e200 and e200R series, Fuze, Clip, Clip+ and Clip Zip
Toshiba: Gigabeat X and F series
If not, ... project! A player with RB and phones with the best fit/comfort (and then eq them into submission!
Good review of the Clip+, you should condense it down a bit and post it as a ... review!
Too bad it didn't work out for you. It works well for what I ask it to do. Crap, what was it again you wanted ... oh ya, a player to bike with, right?
Dude, you are quite the investigator and really dive into a project! Your learning 'curve' goes almost straight up! 😀 Myself and, I'm sure, a lot of others get a kick out of your posts!
Jeff
MPIO: HD300
Jeff
Sounds like he's more dissapointed with the Sansa Clip. I don't blame him; if I saw his post about buying it I would have suggested looking for something else. I've had a couple Sansa products and they aren't exactly high quality devices (IMO).
If he's really serious and wants a good player, you can still find iRiver iHP-120 and iHP-140 devices on ebay. A little pricey still for how old they are, but they're worth it if you don't mind their bulk. The H320 and H340 are good too if you don't need the optical output.
I do like it.Dude, I thought you would like Rockbox!
I actually like most open source software because that is a "made for using" sort of category that almost always gives a different and perhaps better quality experience than a "made for selling" type.
Brute force approaches can't ever match the power of tuning the signal to match the receiver: Is there some possibility of adding an ultrabass or psychoacoustic bass enhancement that could deliver more hearable bass without eating up any headroom?
Is there some possibility of upgrading the MP3 decoders, or do you know of some specific MP3 codecs and settings that this player can decode most successfully?
This, when in combination with the digital radio's auto-damper allows a clean immersive experience with a non-shout tone, while listening to the radio.Isn't the digital cross-feed awesome!
So, although I dislike the Mp3 section, due to decoding quality and power output, the rather good radio makes it worth keeping.
Your post informed me that the task was doable, so with that inspiring some confidence, I just kept at it until the device worked as described. My learning curve, like with most people, is totally reliant on the amount of stubbornness. However, thank you for the wonderful compliment.Dude, you are quite the investigator and really dive into a project! Your learning 'curve' goes almost straight up! 😀 Myself and, I'm sure, a lot of others get a kick out of your posts!
Sounds like he's more dissapointed with the Sansa Clip. ..
Rockbox =/ Sansa Clip+
Sansa Clip+ is a small, cheap audio player (he no like)
Rockbox is firmware that can run on many players (he like)
Daniel, I have an iRiver iHP-140 around here somewhere. I need to get a new battery for it, but maybe you would interested in borrowing it to see if it meets your needs?
...Your post informed me that the task was doable, so with that inspiring some confidence, I just kept at it until the device worked as described. My learning curve, like with most people, is totally reliant on the amount of stubbornness. However, thank you for the wonderful compliment.
Well, and humble as well!
Dude, you are p r o l i f i c ! I've been following the gainclone threads and you and another poster have given enormous amounts of time to posting your testing and info.
You do us all a great service and I guess you didn't understand that!
And look what you get for your appreciated contributions ... a small token of our goodwill (perfect Anonymous1! Does the iRiver iHP-140 have a buffer)!
I wish you luck and look forward to you finding a player/phone that's a good fit!
Your extensive FLAC use gave me an idea. . .
I've completed an extensive codec comparison on the Sansa Clip+ RockBox by trying every lossy codec on the list.
It took a long time!
There is 1 lossy codec that it understands without making the treble quality of jangled coins, fuzz, whines, static or smear.
There is only one.
The Sansa's flaw of trashing HE content is solved by the one codec that puts such content into a separate file that we omit so that the actual fix is to set the LC basic content to a high bitrate. Like the FLAC approach, my dodge avoids incompatible input that the Sansa distorts horribly. If we don't put that in, it doesn't come out. 😀
WavePack 24 bit, auto dithered and at least 224kbits with "effort" level about 3 and no "correction" file, is the compatible codec. This is a very slow encode/transcode and takes up some space. But, the replay quality is noticeable, and the space consumed by WavePack hybrid in lossy mode is far less than Flac. True transparency for WavePack hybrid comes somewhere between 350kbits to 400kbits; but, that high is only needed for very complex programme such as multilayer instruments in orchestras.
I've stopped over at the Wal-Mart today for a 32gb TF card. Meanwhile the computer has been busy making a copy of my collection in WavePack Hybrid, 24 bit, auto-dithered (lossy sources only), using Foobar2000. I'm accostomed to MP3 playback with Foobar2000, and the prospect is to make the Sansa play my files exactly like that.
I've never used WavePack before and I don't have a favorite, but the Sansa likes it. Subtract a miniscule quality hit for the transcode, but much to the benefit of the Sansa being able to decode it sensibly.
It is working!
This has reduced the reliance on stereo expander and EQ tricks. I haven't decided if the WavePack approach has done the job yet or not, but there's a remarkable difference in all the settings. Most of the treble hash and the severe headroom issues seem to have disappeared. Another change is that the battery lasted several hours longer.
Perhaps this WavePack approach is similar to converting everything to FLAC, although the storage consumption is much different.
P.S.
That's about as far as firmware and software can get us as for avoiding irritating the AF output section. Normal caveats of miniature devices are still present. I understand the current handling troubles and minimum bias in this tiny player, since they didn't want to make it larger to fit a bigger battery for supporting adequate electronics. At end result, software doesn't fully substitute for parts.
There is only one.
It is working!
P.S.
Thanks to theAnonymous1 for the clues and speaking of significant electronics. . .
For the price of some earbuds, I got an Iriver H10 5GB, formatted it twice with the firmware upgrade tool and swapped it over to UMC loaded up the high speed tweaked firmware, got it flying along at high speed with no lags, saved a copy of all the pertinent files and utilities, and then loaded up RockBox UMC. No struggles on shuffle mode or movies. Yep. Its perfect. Ironically, HiSoundAudio PAA1 Pro earbuds came in the box with it, which was a big surprise. These have the older blue casing but not PAA1 drivers, but rather PAA1-Pro drivers and Sennheiser brand name. They were free with the player and hadn't been mentioned in the advertisement. I did manage to splurge $9 for a sturdy battery and $8 for a spare Seagate Flex-ATA hard drive. So, this brought the whole kit up to the price of the earbuds that were included with it at no extra charge. That's just somewhat ironic and fortunate.
The Iriver plays as well or better than my PC, regardless of the codec used.
High Quality Earbud Reconnoiter!
Markings indicate PAA1-Pro/Live (very expensive at retail):
Back in this date of manufacturing, earbuds without the chrome stripe were PAA1-standard with less treble resolution, and earbuds with the chrome stripe were PAA1-Pro with very high resolution for an earbud. Both offer a reasonably level response and powerful clean bass.
Caveat!: Not every earbud in this casing has useful drivers inside. For example, I believe the orignal combination has been discontinued because I did buy some new Pyle branded product in that same casing with junk audio quality--Problem: The Pro/Live has been redecorated and the old style casing has been recycled as a low end product.
So, new product will appear differently.
Searching the Sennheiser lineup. . . MX-365 has a possibility of containing the HiSoundAudio drivers. I don't know if those or which Sennheiser has HiSoundAudio drivers inside or which grade they might be.
Other redecorations:
$50 (theoretically the same as what came with Iriver H10-5)
$100 (more decorous appearance and right-left matched)
These are from the actual manufacturer and have the same drivers as what came free in the box with every Iriver H10 5gb mp3 player. When original manufacturer also sells retail, it is typical that they will change the appearance and mark up the price and make other differences to avoid competing with their largest clients, like Sennheiser.
THAT is the excellent surprise found in the bottom of the old cardboard box with the used Iriver H10 player. Wow! As a bonus, the player is pretty good too! 😀
P.S.
Hisound "live" at about $100 is the one with Sennheiser sound and good bass. However, at $200, Hisound "Living" imitates Grado sound with excellent resolution at the cost of no bass. So, don't spend too much.
P.S.
Sorry for the delay on fixing up the Sansa Clip+. I was distracted by an old Iriver and an epic reconnoiter made worthwhile by a lot of really high quality jammin out. 😀Ya, not prolific at all (that was only like 3 days)! 😉
What headphones did you try with the clip+?
Headphone sources generally put out very different amounts of power into different headphone impedances. For example the Clip+ portable player can put out 16 mW into 16 ohms but only 0.8 mW into 300 ohms. The FiiO E7 can put out over 100 mW into 16 ohms but only 2.8 mW into 600 ohms. And some sources are not as compatible with low impedances such as the Mini3 and FiiO E9.
NwAvGuy: Headphone Impedance Explained
Thanks for the info on the headphones. Actually, the headphones that came with the Sansa are plentifully bassy and easily mask the Sansa's treble hash along with a bit of the audio too. I tried several other headphones.
P.S.
The similarities are uncanny.
P.S.
Hey Daniel,
You did all that investigating into the clip+, I would love to hear some of your results! Is there a particular song you could post encoded a few different ways that shows the distortion?
Only if the files are still around etc ... I don't want you to go to any fuss. Sounds like you've got some awesome projects on the go ...
In a similar vein, you did that great work with Rockbox; would you like to post it over at the Rockbox forum? If not, maybe I could post it for you.
Jeff
Jeff
Yeah, you could quote the Iriver paragraph from post 51 if you wanted to. There's some links that would need copied with it though. The information was almost lost to time if it hadn't been for the Wayback service. Before the mods, that player was a sluggish old thing. But, now, she starts up in 0.78 seconds from button push to rock your socks off.
The WavePack approach with the Sansa Clip+ is mildly interesting if one had already purchased the Clip+ and WavePack at high bitrate is certainly more space efficient than Flac. Given the high power CPU in the Clip+ there should be some possibility of running a live time noise analysis de-fuzz sort of filter or some similar way to provide it a signal that does not aggravate the cheap analog section's tendency to hash up the treble. If it had such a filter, that could give a "load and go" convenience instead of the extensive pre-processing and/or transcoding we do currently. Basically the Sansa has "bad dac" symptoms but I can't tell if it really is bad dac or if it is no-bias battery efficient output section. This easily irritated output is hit or miss compatible with sound files and that's not really "load and go" convenient except for low quality results.
The two items photographed in post#54 are very similar including output quality and should probably be avoided since there are so many other players that could do better.
Can you post a song file that has very obvious "hash up the treble" on the clip+ so I can see if I hear it with my clip+ and various phones.
Thanks,
Jeff
Thanks,
Jeff
Loud bass. Maybe too much.
Sansa Clip+ factory earbuds and hisoundaudio paa1-pro are very similar with super-loud bass and appear to be related. The more expensive hisound are matched for left right balance and have metal screens for better imaging at the cost of having to use the pads. These sound somewhat like Koss SportaPro/PortaPro. No problem competing with the bass of earplug types. But, there is perhaps too much of a good thing. For generic players, these will all work on the "jazz" setting, a milder version of the "rock" contour.
The Paa1 original that came with the Iriver H10 has a bit less bass but much finer imaging, and a mostly level response. But, it seems that model is discontinued unless Sennheiser redecorated it.
There appears to be a huge variety with earbuds!
Pre-Process One
I have a new plan for the Sansa Clip+. But, it involves an inconvenient interstage approach and a sturdy computer with a large hard drive.
Step 1:
A custom copy with built in and non-fluttering headphone suitable ambiance that we'll fix up in step 2; so, this first step is all about getting some source material not reliant on joint stereo channels and not prone to hash or flutter.
Foobar2000 transcode to Wav at 24 bits:
Go to Foobar2000 preferences, advanced, find converter, and set the number of threads to 1 (block simultaneous conversions) so it doesn't crash or convolute or severely fragment your hard drive.
5.1 Headphone experience *Foobar configuration for all stereo music files*
Almost just like that, except:
Dolby headphone to #2, live room
Channel mixer upmix rear volume 1.75
Channel mixer check "Add low freqs
Channel mixer low freqs volume 1.25
*if you get clipped output, add foo_invhardlimit.dll to the top of the dsp list.
Create playlist
Select all
Right click and choose Convert.
Select Wav type, select 24 bit, no dither, put all of the above dsp stuff into the Processing (double check all settings too) select an output folder on your hard drive and go.
*The properties-advanced DSP section for playback is separate from the Converter DSP section. Make sure to double check all settings in both places. And, check all converter settings each time before conversion.
At this time, it is necessary to remove all DSP's from Foobar2000, preferences, playback, DSP. The output files already contain the ambiance, so we have to remove the DSP's from the playback section in order to hear it without doubling up.
This was the first step.
The next step is to filter noise with a radio station processor, free SA Stereo Tool and regulate the stereo imaging, all for clarity. Due to complexity, it is not possible to do this all in one fell swoop, so that's why the inter-stage is Wav at 24bits.
I can't post copyrighted material to diyaudio.com. It was every Joint Stereo (normal mp3 files, like LP, FM and Tape is also Joint Stereo) mp3 that does this, especially bad when combined with stereo widening and/or crossfeed.Can you post a song file that has very obvious "hash up the treble" on the clip+ so I can see if I hear it with my clip+ and various phones. Thanks, Jeff
Step 1:
Create playlist
Select all
I can't post copyrighted material to diyaudio.com. It was every Joint Stereo (normal mp3 files, like LP, FM and Tape is also Joint Stereo) mp3 that does this, especially bad when combined with stereo widening and/or crossfeed. ...
What's 'Joint Stereo' ... is that old hippy classic rock! 😉
What rate mp3?
Thanks,
Jeff
- Headphone Systems
- Best Earbud (not earplug) headphones to buy?
