What about the symmetry of the circlotron?
What about the symmetry of the circlotron? Each driver circuit is symmetrical and produces similar voltage swings. The balanced inputs are of the in the same voltage range. The only thing I see objectionable is the way that ground is derived using a resistor divider between the output terminals.
Alas, different people have different views of what constitutes symmetry. The blind pusuit of any particular symmetry at the expense of common sense should be avoided. Just because both the push and pull output transistors are the same type in a quasi-complementary output stage does not make its operation the least bit symmetrical.
Similarly, those who pursue symmetry just because it looks cool on a schematic are just as likely to end up with a poor-sounding amplifier as anyone else.
No amplifier design that I know of is perfectly symmetrical in every sense. Pick your poison, but do so wisely.
Bob
Re: How about the circlotron?
BTW: In my previous post I was referring to the version of the circlotron described in Michael Rothacher's paper "Build the the Amazing FET Circlotron".
http://www.passdiy.com/pdf/Build%20T...Circlotron.pdf
Yeah,
this one looks symmetrical, but features 0.05% THD20k (third harmonic dominated). This is not really impressing at all, perhaps the author should have driven the power MOSFETs nonlinear capacitances with little more authority ...
![rain :rain: :rain:](https://files.diyaudio.com/forums/images/smilies/raincloud.gif)
Like Bob Cordell said, not everything which looks amazing sounds or measures amazing ...
Let me guess, this Circlotron beast sounds a little hot and edgy with lots of muddy bass ...
Audio compatible MOSFETs from Fairchild ?
Here again my question, did anybody test these:
FQA36P15
FQA46N15 from Fairchild
These seem to be rather powerful and robust VMOS (planar stripe) type, are damn cheap, low Crss and can dissipate at least 250W.
They already worked in a prototype of mine, but I never qualified them any further (measurement and listening wise).
FQA36P15
Yeah,
Yeah. I don't know why Rothacher didn't stick with the 50 ohm / 10 ohm feedback that was used in Nelson's F5. His circuit is otherwise identical to the lower half output of the F5.
In my opinion best mos-fet for output stages are laterals. I had used with great results ACD100NDD and ACD102PDD from Semefab. Currently they are powering my latest Quasar ver.13
Regards,
Tibi
Thanks for this, Ive been waiting for someone to comment on these, seeing from your site that you have used the exicons before and these give good results Im very inclined to try them out too, at last a affordable lateral.
tibby:
where do you get those mosfets and how much do they cost?
mlloyd1
mlloyd1
A picture.
Regards,
Tibi
Something is odd with these ACD laterals...
- Datasheets are hard to find, and the ones I found on french DIY site (2A & DIY) read "preliminary" and "custom design for Class-D" (the company). The link placed at Pro Audio - Alfet Lateral MOSFETs goes into the voids...
- They appear in the Semelab stock list for Magnatec brand parts but then again they do NOT appear as official Semelab/Magnatec products (that's the custom aspect above, me thinks).
At least it looks clear that they seem to be basically the established Semelab lateral design (sold as Magnatec/Exicon) with some redesigned die placement and bonding for the double die parts...
To late to edit above post...
.. but now I found what look to be the "official" Magnatec parts with improved oscillation stability, and better looking dataheet curves (compare the transfer characteristics vs. the ACD datasheet curves) :
Magnatec. ALFET Lateral MOSFETs
Of course it is still unclear if and how much they differ from the Class-D custom parts... to me it looks they might be the very identical parts because the ACD's have that "Alfet" tag on the Pro Audio website plus the info given on the magnatec webite.
Seems the Brits love to confuse customers (they already did with Magnatec vs Exicon brands; an application engineer from profusion.plc told me that they are absolutly identical parts to the best of his knowledge).
Klaus
Klaus
FQA36P15
Hi
I use these types of fets in my amp, although not exactly these particular ones, they're all similar. As you can see they have terrible transfer characteristics compared to lateral fets but then they are really cheap
![ill :ill: :ill:](https://files.diyaudio.com/forums/images/smilies/ill.gif)
Hi
I use these types of fets in my amp, although not exactly these particular ones, they're all similar. As you can see they have terrible transfer characteristics compared to lateral fets but then they are really cheap. Of course all mosfets have the non-linear capacitance and variation of Vgs vs Id affecting linear operation, but with these you can see on the datasheet that Id is quite dependent on Vds.
These devices are obviously designed for switching but, IMO, if you wish to realistically use these for a quality linear output stage you have to use some sort of EC. I do think that if you have no fear of the extra complexity, using a proper EC gate drive circuit is the way to go for all mosfets. I use the feedback/feedforward of HEC and, if implemented well, it works quite nicely. These fets really are very tough components even after thermal de-rating. Unfortunately they also require a bit more bias and a more robust driver circuit. Here is an example of how I used them. Obviously the IL300 is not required, I was just having fun experimenting.
This first build is a success and I'm on the second build (I have 5 PCB's), but now I'm out of town on business for a couple of weeks.
I agree. Also I simulate it like this:
http://www.diyaudio.com/forums/ever...eally-i-post-some-proof-here.html#post2203189
and they looks amazing, even old IRFZ44 (without N).
Hi
I am always leary of simulation results used for predicting the finalized real operation for output stages because simulated devices are not subject to thermal stress and the physical changes in operation of the devices related to those thermal changes. But it will show the general operation of such devices. Here is an example of EC showing the related distortion with complementary hexfet transistor followers of relatively equal trans-conductance that I posted a couple years ago. One important thing I found with the HEC circuit is that the error amplifiers must be in physical contact with the outputs because to not have them as part of the thermal transfer fucntion creates a variable bias depending on the random temperature of the error amp components. I have since scraped the idea of a seperate Vgs multiplier. But the experiment shows the error signal required to undo most of the terrible distortion these transistors inherently create. Another point to make about this type of error correction is that not gain but rather bandwidth of the error amplifier is what's important. The higher the BW the more error can be corrected for. Because of this, I would not recommend using op-amps as the EC amps because they are generally limited in BW compared to a single transistor stage. Also a global fb loop is quite limited in this task as well because of the many stages within the loop and that the BW is purposely limited in order to maintain stability around the VAS due to voltage gain being greater than 1. Hence the issue with using hexfets as a straight up follower. Most people hate these devices for this reason and that they do not know how to stabilize them correctly but I feel those folks have not had a chance to experience them properly to see, or rather hear their true potential in overall BW and power handling ability with regard to driving reactive loads.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Actually, no. Quite the opposite, in fact with a variety of speakers.
So Michael, how do you compare the ciclotron with the F5 and other amps which have more dominant H2 than H3? Thanks.
- Best MOSFET for output stages
