Best resistors For I/V Conversion?
The bulk foil Vishay resistors for I/V stage that some of you are using are the same with ''Z201 Series''?
Have anyone of you noticed sound difference, lets say, between 0.05% and 0.1%?
Kind rgs,
Alex.
So digging deeper, seems that are two series:
VAR series, that is naked Z-Foil, audio grade
Z201 series, that is plastic cased
Same question remain, have you used VAR series or Z201 for your I/V resistors? 🙂
Have a great weekend!
Alex.
NSL32SR2S???
You could try one of these to see what it sounds like in this very low power position.
You could use NSL32SRS that I use in the "Lightspeed Attenuator" and fix the led brightness to it to give the R value you want. Many including myself believe they sound better than any type of resistor, being made from CdS (Cadmium Sulphide).
And you could vary the R on the fly by changing the led brightness to find your optimal listening preference.
Cheers George
Bruce Hofer of Audio Precision, in his Analog Master Class seminars, mentions that the best 5ppm thin film R are the real deal for measured low distortion at audio frequencies
it appears that Hofer is saying that some bulk metal foil don't perform proportionately as much better than some thin film just considering TCR
a guess would be that the extreme low TCR are obtained in part by balancing mechanical strain and TC of substrate and foil - so there is a more complicated thermo-mechanical effect that doesn't work to full benefit above fractional Hz and below kHz
but the foil still has as low TCR as any thin film as far as I know – so it shouldn't actually be worse than thin film – just not as much better as might be expected by the DC TCR ratios
it would be useful to know which “some bulk metal foil” are that show this – Z foil? - differ between chips, leaded, “naked”, fully encapsulated? as well as the numbers, plots
NSL32SR2S???
Cheers George
Hey, 😎 : It could work with such as low current ?
Vishay's bulk metal foil material comes in several grades, the Z1 foil is their current most stable material, the rest is mostly in packaging to absolutely minimize temperature coefficient. Bulk foil, thin film and wirewound resistors are all typically made of nickel-chrome alloys (with 'secret' ingredients); the foil is much thicker than metal films and has a much better voltage coefficient. This is an advantage shared with wirewounds over thin film, especially very high resistance films. High stability wirewounds may rival bulk foil resistors in sound quality, and I tend to think of bulk foil resistors as miniaturized wirewounds.
There are some very stable metal film resistors, such as Vishay/Dale PTF series, that approach foil resistors in temperature stability. These may sound better than run-of-the-mill 100 ppm TC metal film resistors.
Vishay offers enhanced stability grade Z-foil resistors that are 'pre-aged' to remove the last traces of drift (generally below .005%), and hermetically sealed in oil to further enhance stability by eliminating moisture and oxygen from affecting the foil and to heat sink the resistive element. They'll be priced accordingly and I wouldn't bother with them, just that those resistors are probably the 'ultimate' in stability over time and environment, where absolute value is important, as in metrology applications.
I don't think there are any great differences between metal foil resistors that are rated by tolerance, such as 1%, .1% or even .001%; just that they are stable enough to hold that tolerance over time. That's slightly more desirable.
I've found RNR series metal film resistors that are hermetically sealed in glass with argon (or helium?) and gold leads, but these are just metal film resistors with a military/ aerospace grade reliability and environmental protection. The resistor element and end caps are clearly visible through the glass package (no paint) . I doubt they are 'special' in any audible sense, but I don't think audiophiles have yet 'discovered' these parts and have tried listening to samples.
There are some other materials used as resistive elements, such as tantalum nitride that may be of similar quality to nickel-chrome alloys, but they are uncommon and I've never used those types.
I prefer Rhopoint GG102 Squaristor over TX2575 in DDDAC 1794 as I/V Resistor.
Very good specifications, closely approaching bulk foil resistors; adding them to my list since their form factor is nearly identical (probably intentional).
Caddock makes excellent thin film and possibly thick film resistors with excellent specifications and some audiophile popularity; my only quibble is their larger size and somewhat limited availability. Doubtless there are more resistor types out there from cost-effective to expensive high performance types.
--Damon
Allen Bradley is strangly very good here as well!
Shinko works fine.
Remember Peter Walker used to putt a Cadock with the TDA1543... read it here somewhere in a long thread about the best résistors (no I/V mentioned in the title but talked in the thread)
I'm a big fan of wire wound resistors for precision applications, but there's no such thing as a zero inductance wire wound resistor, and some winding techniques also produce significant stray capacitance. I'd be a bit leery of using them for high bandwidth I/V conversion. The bulk metal foil resistors best wirewounds in just about every way except maybe peak power handling, and I'm not even sure about that. A decent metal film like an RN55 or 60 type is also no slouch. The value of the resistor would affect my choice of type. For low values the wire wound can be excellent. For mid values the bulk metal foil or MF wins, and for high values the MF is the logical choice. Don't go near thick film, carbon film, carbon, or MOX resistors due to instability, noise and non-linearity with voltage, in spite of sometimes excellent HF performance.
Bro, I do the same thing
Wirewound rhopoint gg102a for below 100
TX2575 above that
I think these are relevant and instructive vs the choice of resistor types:
"http://www.analog.com/media/en/training-seminars/tutorials/MT-019.pdf"
"http://www.ti.com/lit/ug/tidu022/tidu022.pdf"
The inductance of a wire wound resistor in series with a nul point input would tend to filter digital glitches but there are many better ways, the best of which would probably be a sample and hold.
Hi ... I have listened to both the squaristor and Charcroft version of the TX2575 and they are somewhat different to my ears. The Charcroft is very clean and open - extended - and appears to have very little coloration, neutral. The squaristor (again to my ears) has more midrange tonal bloom & level, however, seemed to have an upper midrange/treble "tizziness" compared with the Charcroft. Very musically sounding.
Jesper
