Better part National 2N5566, or Linear Systems LSK389?
Capacities may be important
If you use the dual FET as differential input stage fed by a varying source impedance, for instance from a volume pot, then the capacity between gate and drain may be important. It can easily worsen the THD figures, if you target very low values. In this case, something like LSK489 is preferable, and 2N5566 seems to be even better (with slightly lower transconductance).
