CAB 2000.1 Protection Flashing
I'm not sure what your asking me to check here? Below is resistance across rectifier pads on board with rectifiers out.
Pin 1-3 for each rectifier is steady .7 ohms(DMM Lead Resistance)
Pin 2-3 and 2-1 charges a capacitor in circuit
What would be the best way to test this? I have less than ohm across the 3 solder points for the secondary winding on the back of the board pictured earlier. I do not have an inductance tester. i did try to manipulate the transformer while powered up and did not get any change.
I pulled the secondary winding's and wired in jumpers and it does the same in and out of protect. i desoldered the jumpers and the amp does have good drive waves but the green light does not come on and it does not light the protect light either.
With thesmall wires attached to board going to lifted secondary windings it flashes in and out protect (LED's are flasimg red then green...)
With the secondary windings lifted the FETS are making a good square waves but no LED comes on ( red nor green are illuminating). I do not believe it is powering completely up when I have the secondary windings lifted.
I am using a 12 volt battery with an inline fuse the battery rests at 12.65 volts. I hooked up another amp today and it functions with no issues. When I first opened this amp up the power input solder wasn't great (maybe got hot or poor from factory) so I refreshed that and I am getting good voltage to pin 2 on all PS FET pads.
I put 4 FETs one per bank all batch matched and no change. It is still flashing in and out of protect? I think there is a short somewhere in the positive rail rectifier circuit (this is a hunch) causing a over current.i can't find any short though?
