Hey,
is there any way of telling how many ansi lumens there will be in a projector?
like a formulae or something?
say if there's a 25,000 lumens MH light, how many ANSI lumens would there be?
10% is a pretty good starting point.
However you also have to factor in the loss of light from your reflector and other things, really 10% is a high guess. You may be able to get that good of efficiency but likely will not... I'd say 5% would be a better general guesstimate.
let's say it's average 5% by a DIY, what is it by a manufactured build projector, just to compare ?
And is it ALWAYS better, the more lumen the better picture, cause you can overlight the screeen I guess. Like using a 1000watt bulb is it usefull EVERY time, I guess not ?
Read the following thread. It is a little off topic, but explains about the amount of light passing through the lcd.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=10231
Great Just wat I was looking for, man so Now I can see whay they can Ctick it to us😱 on the projector bulbs at 400+, hummmm any thoughts if 2 400 watt MH will be too hot to retrofit into a OHP?
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- Calculating ANSI lumens
