My question is
can you add internal bracing to an already made pair of speakers?
would it alter the sound in a bad way or in a way the speaker designer didn’t have in mind?
i was thinking of adding low mass aluminum rods inside in a cross pattern to increase stiffness of the cabinet.
im assuming it would ruin the sound of the speaker the way it was designed from the woofer selection and crossover the designer used?
thanks!
thanks!
i have all the materials in mind so that it is completely reversible. No glue or anything.Not easily is my opinion, Corner blocking maybe
If the commercial box is small it may not have been needed in the first place
would be like chin up bars which use external force to mount.
of course I wouldn’t over tighten at all
Hard to do a really good job with adding really good bracing, but as much as we could do (most of the time), just single point braces like Geddes, adding bracing was one of the steps we would take to make a commercial loudspeaker better.
dave
whos Geddes?
would adding the single point braces shift the resonant freq up higher?
thanks!
Years ago, when I repaired and upgraded my floorstanding Advent Maestro speakers, I added in a wood brace just above the woofer, in the center of the enclosure, from front to back.
Simple, stiffened up the front/back panels nicely since it's an air-suspension/sealed box.
Bass is clean, plenty of lows, I'm happy with the results.
I wouldn't say it changes box tuning, but cabinets tend to resonate. They shouldn't necessarily, so it isn't right to think that cabinet vibrations are supposed to be there.
However, people often find they are disappointed after bracing a speaker that they already like. Sure, if you then proceed to do it properly and fix all issues it will come good again, but this is difficult to do and perhaps only worth it if the speaker is suited to you and your room in other ways.
Maybe try something reversible at first.
I meant the foam tubes used for covering / insulating copper tubes used in HVAC installations, particularly to split A/C outdoor units from the indoor units.
Or something like that to cover the aluminum rods you want to use for bracing.
Use foam sheets for the inside walls, with weak glue.
Based solely on this review there should in theory be precious little to do beyond mass loading the drivers if not already part of its bracing.Proac DT8
Dr Earl Geddes.would adding the single point braces shift the resonant freq up higher?
![Tappan-braces.gif](/community/proxy.php?image=http%3A%2F%2Fp10hifi.net%2Ftlinespeakers%2Fforum%2FTappan-braces.gif&hash=343bdfa13010150cb3cd70fe805d655a)
dave
How do you know that your current cabinets aren't braced?
uh cause I looked inside?
lol
sorry wasn’t trying to be snarky.
I was thinking it may have a shelf brace positioned behind the tweeter, which is pretty much a standard way of doing this type of tall MTM
nah. It doesn’t unfortunately. its not tall at all man.
around 38.5” with spikes.
i have it raised a bit higher at around 40”
It's considered tall due to the height Vs width aspect. OK I checked your other post and no shelf brace.
ah didn’t know it was considered tall
thanks for that info
- Can you add internal bracing to commercial speaker?
