capacitor array for starting engine
gtforme00 said:
I don't get it?
You'll get it if you've seen a picture of Peggy Liska, one of his first engineering friends. (I don't have a picture. In fact, I don't even know her very well.) Let me just say that the original joke had to do with capacitance of the main capacitors in a PC power supply.
One day, he brought a 0.1F, 50v capacitor that he was going to use for his model race car project. He had to call it "Peggy-sized", of course. (Oh yeah, the model car took off like a rocket. He used the capacitor itself as a weight to improve traction. It's about 1/10th scale.)
martin clark said:
Very true, but a lot of those are now LiPo whereas dumb old NiCd is very forgiving of charging regime, standing around unused etc...
Nano-LiFePo cells from A123-systems are worth checking out. Much more robust technology than traditional LiPo-batts and capable of serious peak power.
http://a123systems.textdriven.com/product/pdf/1/ANR26650M1A_Datasheet_APRIL_2009.pdf
Eight 26650 sized cells(~12v 4.6Ah) can provide 240 amps @ 9v for 10 seconds, possibly enough to start smaller gasoline engines. 8-cell pack weights less than 600 grams, so obviously you can use more...
Typical lead-acid car battery weights something like 15kg, so for the same weight you can put in 200pcs 26650 cells, capable to output 6000A or 50kW for 10 secs. :hot: Battery pack like that is going to cost like hell, but still definetely cheaper than supercapacitors.
