Carver M400 Magnetic Field Power Amps
I have 2 of these. They are 240V models. They do NOT work. I am considering throwing out the insides and making cute amps using the cute metal work. Could be a nice 2.1 system for my computer desk.
Question, is this a sin. If so is it a big sin or a little sin:smash:
If anyone wants them then make an offer, I will post anywhere and I am posting from AUstralia. Cosmeticaly they are OK, could do with a spray paint job.
Hi Pheoinx
These amps were well regarded, and designed by a very highly regarded designer.
Bob Carver was known for not following trends, and designing his way.
I reckon they are worth getting up and running, especially of they are the "T" model. The T model many say was much better.
Hope this helps.
I just repaired mine. and it wast that hard to get running. the power supply is basically a light dimmer! there are two 2amp bridge rectifiers in parallel for the 25V supply. I guess these fail often causing the unit to blow fuses etc. I followed the instructions in the service manual and the repair was quite easy. just a PITA to get the lil bugger apart far enough to GET to the dang bridges. I upgraded to a single 10 amp bridge rectifier and all was good after that. the service manual is well written and easy to follow.
Zc
I don't remember the M400 being an amplifier that had the "T" option. Does it stand for "tube"? Working there, we called it the Carver "tweak". Didn't see him often, though when I did, Bob was usually jubilant about his whatever it was he was brewing up. Besides the Carver challenge, professional amplifiers for the touring Michael Jackson were big for the company.
