morrish said:Thank you QSerraTico_Tico.
The static comes from the right channel only. (input cables disconnedcted from pre-amplifier.)
This amplifier is a "Duet-350", a two-channel, single chassis, stereo power amplifier with single torroidal power transformer, four large power-supply capacitors (about 37,000mfd each) with rated output of 350 watts per channel. It is neither the very expensive, four-chassis "Performance Amplifier" nor the relatively lower-powered "Encore."
see: http://hso.keskipiste.com/hso_images/7duet350open.jpg
Well, well, never operate a high power high bandwith amp with open inputs.
Use shorting plugs at the inputs or leave it connected to a switched on preamp.
Use cooling spray (ice spray) on small transistors one by one in the right channel to find the "cracker".
Before this thread is completely forgotten I want to draw a bit attention to the Darlington transistors Q12 and Q13 (here Cello Encore ). I guess these are part of the biasing of the output stage, but it would be great if one could help me a bit to understand how it works!
Come on guys! Ever seen such an asymmetric design?
Have fun! Hannes
Have fun! Hannes
My guess, likely more accurate at higher freq. and the C makes the output stage more stable.
(D12/D13/R33/R34 raise the front end voltages to boost the peak output power)
jacco vermeulen said:Q12/Q13+R35/R36 issa shunt voltage regulation for the front end.
I don't think so. It is a clamp to limit the output swing of Q9 and Q10. This way the output voltage is limited before Q9 or Q10 start saturating. The output current of Q9 is diverted via R34, D13. The same for Q10 via R33, D12.
Steven
Steven,
and Q6/Q8 ?
(i see that the 2K value of R37/R38 will hardly make Q12/Q13 stabilise anything)
and Q6/Q8 ?
Great to see that a small discussion started!
I still do not have much of a clue what the the term 'sorted' for Q16 and Q18 in the output stage could mean. Sorting for high hfe?
Ideas you topology experts?
Thank you very much! Hannes
The driver and output stage are outside the feedback loop.
The Wachowiak designed Audiolabor Stark from the early 80s has a similar output stage, but uses 3 pairs of Sanken A1215/C2921 RETs.
Ideally, you'd like the drivers and the output devices both curve-traced and matched for Hfe and Vbe.
Very difficult and costly with a multiple parallel device output stage of the Stark, and somewhat pointless as the output devices are Large die Area Parallel Transistor types, but that kind of sorting is manageable for pairs of MJE1503* and MJ1502*
(Q7 is an oddball, there's a dot-connection missing on it's emitter line)
Let's hope Steven sticks around.
Sticking around
There is no need for R37/38 to have a lower value, they are just pre-biasing Q12/13 to fix their emitter voltages to Vcc*R41/(R40+R41)+2Vbe and -Vcc*R42/(R42+R39)-2Vbe, respectively. If the output swing of Q9/10 becomes too large, D13 starts conducting on the positive peaks and D12 on the negative peaks. The currents through these diodes will be absorbed by Q12/13 and flow to ground (collectors of Q12/13).
Steven
jacco vermeulen said:...i see that the 2K value of R37/R38 will hardly make Q12/Q13 stabilise anything
Steven
The other
Q6/8 will never saturate so they do not need a clamp to prevent that. Current mode only.
The dot on the emitter of Q7 and the collector of Q8 is missing indeed. Then Q8/10 is just a 1:1 current mirror. Q7 is a cascode transistor that limits the Vce of Q6 to approx Vcc (=supply voltage) instead of 2Vcc (without Q7). The twist is that the collector of Q8 is not connected to its own base but to the emitter of Q7 instead. This way also Q8 has a Vce of approx Vcc. The dissipation in Q8 is then the same as the average dissipation in Q10. The same is valid for Q6 and Q9. This is very beneficial for the thermal balance. As an additional benefit Q7 can be very small, since it only deals with the base currents of the current mirror and the current through R30. In normal cascode operation Q7 would have carried the whole collector current of Q6/8.
Steven
jacco vermeulen said:Steven,
and Q6/Q8 ?
Steven
Steven,
Thanks for the enlightening analysis. Could you please provide your insights about the feedback scheme of this amp?
And what about R48, D19 and R49, D18?
Giorgio
Giorgio
More...
I haven't figured out yet how the power stage is exactly working, and I'm afraid that some simulation is needed to get real insight (or building and measuring). It looks like this circuit creates a sliding bias to keep the output transistors conducting and avoid or reduce switching distortion. Maybe even some error correction takes place, using the bias transistors Q14, 15. It looks a bit like, but it's not the same as the Hawksford error correction.
D18+R49 force some 30mA through R50 +R52, creating a voltage drop of some 130mV across these two 2.2 ohm resistors. The same for D19 and R48. Maybe this additional 260mV space can be used to modulate the bias current of the output transistors. Please notice the connection of the output to the emitters of Q14, 15.
Anyway, another feature would be that the output seems to bootstrap the loading resistors R58, 59 of the VAS via C33. Only for high frequencies.
There doesn't seem to be any overall feedback. But this bootstrap will help to make this output stage a more perfect follower. Very clever; I haven't seen this before.
I'm sorry, but I do not have enough time right now to dig into this deeper. Suggestions appreciated.
Steven
Steven
Cello PowerAMP
is very good machine....special the PerformanceII
like it so much....
any body have more information for schematic? photo?
like it so much....
Cello Duet 350 "encore"
Hello all. First post on the forum.
I have a Cello Duet 350 with a similar problem to Morrish's. There is static (pops, crackles, etc...) coming out of the left channel only. Have disassembled the left channel board and there is nothing obviously wrong or burnt (although I think some of the small caps may be bulging a bit).
Morrish - if you read this, did you ever find out what was the problem with your unit? I have looked for schematics but have not come across them yet.
Many thanks for any suggestions,
Cleiber
Cleiber
Static noise from one channel only sounds a bit like a damaged ground connection.
Since you already disassembled the amp, could you draw a schematic and post it here? I'm sure a lot of people would be interested 😀
Have fun, Hannes
Have fun, Hannes
Ha ha ha... very funny... 😉
The main ground cable is fraying a bit, but the "pops" don't get better or worse when I move it. Odd thing is - since I rebuilt it, it only "pops" a few times a day now - no more crackles or hiss. I thought this might also be related to the toggle switch in the back that selects "stereo" or "bridged" - have "exercised" it and used some contact cleaner.
Has anyone had this kind of experience with faulty/old electrolytic caps? I heard some "whistling" noises when the crackles were at their worst - and IME that is normally due to faulty caps.
Thanks,
Cleiber
Thanks,
Cleiber
Well, rats...
For 3 days there was no noise - and then today, it came back worse than ever. Got in touch with ViolaLabs - they think it is the OTA-11 board - and it will cost a minimum of $500 (!!) to fix - and that is *if* it is that board...
Cleiber
Cleiber
- Cello Amplifier troubleshooting
