Rock-ola is still in business, you can contact them:
https://www.rock-ola.com/blogs/news...high-tech-update-of-the-classic-vinyl-bubbler
If you want to directly connect the output of the ceramic pickup to a line level input of a different amplifier (meaning not to the internal tube amplifier), I would recommend a FET source follower (3 components plus battery). The PU is mono, isn't it?
You don't know what you are taking about! Your the only one confused here and there is no mystery. Read the entire thread. A ceramic cartridge needs an input impedance in the meg ohm range or you will lose bass response. Line level inputs are in the kilo ohm range. Why I want to use a ceramic cartridge is irrelevant and frankly none of you business though I did explain it earlier in the thread. Read the entire thread before you make anymore stupid comments. So you want more specifics re what I will plug this preamp into:A generic no name amp?
Or a shop purchased item with a brand name and model number?
Do it yourself amp?
How much output?
Or a generic pre amp circuit? As an all in one level matching device?
Female or not, you are being mysterious and confused.
And ceramic cartridges went out of fashion long back.
Also, their output at times is enough for some amps. No need for a pre amp.
- Technics Stereo Integrated Amplifier SU-V78
- Marantz Receiver SR-6011
- 2 x 4 MiniDSP https://www.minidsp.com/products/minidspkits/2-x-in-4-x-out
No secret just wasn't necessary idiotPrickly, aren't we?
What was so secret about this information?
Wait for the more experienced members to give their opinion, in about 12 hours...I will also tell something later.
See posts 7 and 9
And stop being rude.
The Marantz is complex, your DSP is a boutique item, more show than work.
Enjoy.
From the net:
MiniDSP is a Private company. MiniDSP has a revenue of $3.5M, and 77 employees. MiniDSP has 2 followers on Owler.
It is based in Hong Kong, and gets stuff made outside in Shenzhen, China.
Does not have its own factory.
Founded 2009.
Enjoy.
From the net:
Founded 2009.
Due to manufacturing differences in those amps, they all likely have DIFFERENT analog line level loadings, and sensitivities.
For instance, one might have a 22K input load, another could have 10K.
Another might have 100K.
So with that stated, unless a service manual can weed out and determine those differences, it's almost impossible to design a single adapter that works the SAME way for all of them.
Aim for 150mV output level buffer amp and hope for the best.
- Analogue Source
- Ceramic cartridge to line level input circuit
