You say that but LM4562's are not screened for excess 1/f noise(*) and anyway have _much_ more current noise than an NE5534A - still a great choice for a MM phono preamp...
[ incidentally the NE5534A is better than the NE5532 for preamp duty with its guaranteed noise performance, but isn't
unity gain stable as is, and is single not dual - between them they are probably still about the best value for money for
audio signal chain in the 10k impedance range, about 20cents per opamp ]
Some of the newer JFET opamps are quite impressive, OPA1652 for instance, assuming they don't suffer from the same
production spread of 1/f noise.
(*) LME49720: popcorn noise - Audio forum - Audio - TI E2E support forums
From the datasheets at 1kHz:
Then again the Ti datasheet for the PCM1794 makes use of NE5534 and I must admit that I was impressed with the PCM1794 using just Ti NE5532 before I obtained the OPA1612. The resistors being used are 750, 560 & 270 Ohms or 820 & 360 Ohms. (Depending on which datasheet circuit, figures 24 & 25 in the Ti datasheet.)
OPA2228 0.4 pA/√Hz (!)
NE5532 0.7 pA/√Hz
LM4562 1.6 pA/√Hz
OPA1612 1.7 pA/√Hz
I guess my thinking was that this was lower down on the priority list at least in my application for the PCM1794 or ES9038Q2M. In other words not the factor that I am most concerned with for device selection here. Is that incorrect?NE5532 0.7 pA/√Hz
LM4562 1.6 pA/√Hz
OPA1612 1.7 pA/√Hz
if you really want to find a definitive answer regarding noise you have to look at the surrounding circuitry of the opamp and take all imedances into account. Somewhat similar to what I tried here:
I/V conversion circuit - noise considerations
Looking at current and voltage density noise numbers without context will can be misleading.
Yes. I agree. Thank you for doing the math for my use cases! (ES9038Q2M & PCM1794.)
Interesting. Are there any good links with data for this? Of current production parts which is best? I assumed that Ti used Ti NE5534 for the reference PCM1794 designs.The only "flaws" I am aware of in the NE5532 were the T.I. versions, which were reported to have more HF distortion than other brands. The Signetics/Philips brands were the ones used in all the classic mixing consoles from the late 70s onward.
On Semi? JRC? Ti?
Is anyone else still making them?
Holy F, that double OPA228 is expensive.
I'll take a look at the LM4562. I was always kind of under the impression the ne5532p had some or a lot of flaws regarding distortion. I'm of course trying to make this differential output an improvement over just single ended!
Yes. That is why I mentioned the LM4562 first.
I think I have four OPA2228 which I bought in 2002. I don't remember them being so expensive back then. (But the online order history does not go back that far so I can not be sure.)
I'm not sure if this counts as an op amp as such, but I suppose newer IC's like the SSM2142 will do better for my purpose if I can get my hands on some designs. These are apparently dedicated amplifiers/opamps/drivers for single to diff
Not sure but perhaps look at OPA1632? Just don't get them online (eBay/AliExpress/etc). I bought four online and of course they were fake...
SOIC-8 is not really a problem. You can solder those to double sided perfboard easy as.
Dear-oh! These are sufficiently cheap I'll just buy one of the boards off aliexpress and replace the chips themselves if needed (edit: I'm pretty proficient in soldering & repair.) Interesting, thanks! I have honestly never looked into this part of true design. I always stuck with repair and bodgery on basic amplifier things and programming computer things
You mean this opinion?
LM4562 / LME49720 low frequency noise - Audio forum - Audio - TI E2E support forums
Fake news I tell you.
Couldn't it withstand common soldering temperature?
I am considering OPA1656, but the availability is quite low, currently no stock on major distributors in my area.
My current consideration: OPA1656, OPA1622 (INA1620 for a smaller project), BUF634A, OPA1612
Yes im a TI fanboy
Yes im a TI fanboy
- Choosing of best sounding OP AMPs for the lowest possible THD+N -really the best Way?
