Class A amp based on STK 3102-III
Hi i have a pair of Sony Amps whose output stage is driven by STK 3102-III.
Its simple Emitter follower output stage with simple (not darlington ) driver driving cmplimentry pull-push via VBE multiplier.
Project. Design a separate pull-push Ampliffier output stage , 50W rms class A.
Simple eemitter follower driven by Darlingtons, with multiple x10 output devices at 200mA quiscent current ???
Any design ideas.
BTW i intend to implement fully regulated output stage at +/- 50volts via power mosfet modules/power BJT modules for linear regulation ???
Any ideas? Is the sound Quality of SKT good enough for a real highend style output stage, fully regulated , high bias, fully balance( BTL) ?
Agreed with both Jaycee and 5th Element.
Reason. i want to keep the enclosure , power supply etc from sony. I will take dual twisted pair from SKT outpu to speaker terminal from which i will connect to separate current gain stage externally.
Benefit 1. I have this thing in pair and is bridgeable via a inverter section and selector so i can monoblocks, fully balanced.🙂 and all i have to do is to design and make separate output stage. The existing transformer, 300VA is shielded toriod and will provide excellent regulation for small load of SKT, plus i will use the existing heat sinks in SONY for series voltage regulation at around +/-50V, existing rail voltage is around +/- 60V using IRFP450 200W, 400V, 15A mosfet (which i have in sufficient quantity)
I am going to use a separate enclosure and separate heatsink , separate power supply and separate output stage for final current gain stage.
Here is the schematic of existing output stage.
So is there Any approved/suggested design for class A 50W output stage (pull push/single ended ????) 60_1342059420.gif
