Hi i have a pair of Sony Amps whose output stage is driven by STK 3102-III.
Its simple Emitter follower output stage with simple (not darlington ) driver driving cmplimentry pull-push via VBE multiplier.
Project. Design a separate pull-push Ampliffier output stage , 50W rms class A.
Simple eemitter follower driven by Darlingtons, with multiple x10 output devices at 200mA quiscent current ???
Any design ideas.
BTW i intend to implement fully regulated output stage at +/- 50volts via power mosfet modules/power BJT modules for linear regulation ???
Any ideas? Is the sound Quality of SKT good enough for a real highend style output stage, fully regulated , high bias, fully balance( BTL) ?
Any design ideas.
There's no real reason to use the STK module. They're obsolete, so if they ever need replacement, they're difficult to get. There's nothing special inside them now that you cannot do with a discrete circuit.
I don't know what the Sony amplifier's heatsinks are like, but a standard EF output, biased high enough to give you 50w/8ohm class A, is going to produce a huge amount of heat if run on 50 volt rails.
Agreed with both Jaycee and 5th Element.
Reason. i want to keep the enclosure , power supply etc from sony. I will take dual twisted pair from SKT outpu to speaker terminal from which i will connect to separate current gain stage externally.
Benefit 1. I have this thing in pair and is bridgeable via a inverter section and selector so i can monoblocks, fully balanced.🙂 and all i have to do is to design and make separate output stage. The existing transformer, 300VA is shielded toriod and will provide excellent regulation for small load of SKT, plus i will use the existing heat sinks in SONY for series voltage regulation at around +/-50V, existing rail voltage is around +/- 60V using IRFP450 200W, 400V, 15A mosfet (which i have in sufficient quantity)
I am going to use a separate enclosure and separate heatsink , separate power supply and separate output stage for final current gain stage.
Here is the schematic of existing output stage.
So is there Any approved/suggested design for class A 50W output stage (pull push/single ended ????)
You really want to attach some long wires (=antennas) to a VAS? These wires will have some unpredictible capacitance and will collect a lot of parasitics. What about stability?
Leave that Sony amp as it is and use it as the modulator amp in a Technics class A+ topology (see Power amplifier ). Doing so you'll get what you want: re-use the Sony, a (external) class A amplifier (to be build) and the wires to interconnect them.
I mean if i refer to page 5, for two stage , how i get floating refernece for load on first power supply and how i get fixed reference for second. seems intriguing but a bit of more literature could do the trick ???
- Class A amp based on STK 3102-III
