First Class-d amp
I can't stand to see and empty thread
I think this is the first Class-d amp: US Patent 03011025 in 1961 by Herbert W. Sullivan
A tube amp, and the parts look to still be available today.
Go to: http://patft.uspto.gov/netahtml/PTO/search-bool.html
And search all fields for 03011025
Select the date: 1790 to present
My Boring Website
Since this thread is about Class D design issues......
The Ramblings of a Mind Gone Wrong
A journey into the ins and outs of what Class D might be about from the perspective of someone who is trying to work it out.
DNA
DNA
It's tough. I've been working on one based off a PWM design for a year now and it's kicking my butt. I've got a prototype in the other room that plays, but doesn't sound too good and has a problem with ultra-low frequencies on the output. One of the few amp designs you'll come across that pass the signal through nand gates and optocouplers. On the upside, I think I have designed a successfull output stage for it. (Gotta take pride in the small victories.)
TJNII said:has a problem with ultra-low frequencies on the output.
Check the power supply for the high side switch. It may be dropping too low if it is normally refreshed by bootstrapping.
TJNII said:It's tough. I've been working on one based off a PWM design for a year now and it's kicking my butt.
Hi TJNII. Care to share more about your design with the rest of us?
I'll tell you all about when I get it working right.
I think it has a design flaw in the control circuit, so I don't want to go into too much detail right now.
There are lots of folks around here that may be able to help you find the design flaw, if it exists. Unfortunately that's usually easier to do with a schematic
EDIT:
You read my mind!
EDIT:
Variac said:I think that BWRX meant that if you shared the design some members could suggest what the design flaws might be.
You read my mind!
Well, ok. Since you asked nicely.
Basically it is PWM based off a triangle wave. I generate a triangle wave, and then bias it with an offset voltage to create two waves, one biased positively and one biased negatively. The seperation between them is my dead time between the pull-up fets being energized and the pull-down fets being energized so both fets arn't on at the same time. I then compare the input to these two waves, one wave for pull-up and the other for pull-down. My output stage is an H-bridge so any diffence in turn on/off times for my high side and low side switches is nullified by the fact that (ideally) the pull-up and pull-down current paths are (ideally) identical (ideally). I've also got a minimum pulse width circuit on there, to keep the bootstrap capacitors charged when it is driven into clipping.
That's it in a nutshell. I don't want to post really specific details or schematics yet because I haven't hit a wall yet (I like to solve my own problems, it's the fun of it).
* I know I've roasted my output stage when I turned the dead time control down too low, dissipated around 250W in fets with no heatsyncs. It isn't extra crispy, but damage was done. I think the subsonics are from this because they started after I zapped them
* I know something was odd in the output stage even before that. One fet just wasn't acting right. It doesn't look like a design problem, so I need to look into that.
* I was looking at a class-D design on this board and saw some ideas in the feedback loop I want to steal. I may rip them off.
I'll try that next time. I don't think it is the problem as I took steps to prevent it, but it is an easy test.
Also, I have to start moving so in a few days it is going in a box and won't come out for a month. So I don't want to get really into it now.
And believe me, I'll post details when I get it working. And if I can't, I'll ask when I've run out of ideas. I had this prototype sounding good under slightly different conditions. I just need to test more and be more scientific about it.
My first comment was just that: a comment. I was new and felt like commenting. Pardon me.
Electrone said:Check the power supply for the high side switch. It may be dropping too low if it is normally refreshed by bootstrapping.
richie00boy
is this the ClassD4sure thread you were referring to?
http://www.diyaudio.com/forums/showthread.php?s=&threadid=42146
Major design issues!!
Hi all,
I've been building amps for some time now and i have two very nice sounding prototype classD designs. One is a carrier based, and the other self osc. The problem is i would love to take one of the designs further and complete into a nice stereo amp for my daily amp needs ( the commercial amp in my living room is on all the time i'm in and is getting a bit tired ). The issue i have is this, EVERY CLASS D I BUILD HOWEVER GOOD IT IS ALWAYS ENDS UP DEAD EITHER BY STARTUP PROBLEMS OR BAD LOADS! I know that if used properly they are prob very reliable, but i NEED SOME KIND OF EFFECTIVE PROTECTION against overdrive, overcurrent, bad loads, startup and stall conditions. No matter how much i try i cannot impliment an effective protection system, this is the reason why regretibly i still cannot enjoy these wonderfull sounding amps in the real world, only on the test bench or at occasional parties.
Have any of you DIYers have similer issueswith your designs??
If so and you found an effective way of protection i'd love to hear about your experience.
Mad.P
Hi all,
Mad.P
Multiphase PWM
Has anyone endeavored to come up with a multiphase PWM amp, self oscillating or clocked? This seems to be the solution to the band limiting of moderate switching speeds and the loss of pushing it. There is an obvious difficulty in tuning each phase leg gain to the average of the rest without servo, but it seems possible. With eight phase legs, each one could run at a cool 500kHz, with smaller output transistors, and the total switching frequency would be 4Mhz. Available bandwidth would rival the best linear amplifiers.
- Class D
- Class D Design Issues
