Cracked/exploded Evox Rifa Metallized Paper X2 Capacitors - What Deficiencies?
Those old Rifa caps are metalized paper - they can be replaced with either polyester or polypropylene units of equivalent value. Appropriate safety rating is probably X2. The usual distributors should have them. Be generous with the voltage rating, and they will last longer.
It looks fine but shows as out of stock for me. These caps are not critical apart from having to be safety rated.
You can just snip the old one out for now, it doesn't need it to work. M can mean 20% tolerance (not critical here) and MP could be Metalized Polyester (the type).
https://cpc.farnell.com/vishay/bfc233620103/capacitor-class-x2-0-01uf/dp/CA07137
what about the currently available "RIFA" branded successors from KEMET regarding reliability and life time ?
https://electronics.stackexchange.com/questions/437683/rifa-pme271m547-replacement
  • RIFA PME271M.pdf
