Dale / Vishay Resistors
Hi
Until about 2 - 3 Years back I was able to Order Dale Resistors almost any kind I wanted.
Before that until 1992 there where Resista Resistors from Germany if I remember right. Then there was the announcement that Resista would stop to produce Resistors and the the company would be sold to Vishay..
After that Resista dissapered as well as the resistors.
10 Days ago I ordered Resistors using FARNELL Distributor. There were no DALE anymore.. ONLY Mulitcomp.! When I got them a few days back, half of them were RESISTA.. I don't get that anymore.
I would like to buy DALE RESISTORS, cmf55Series. Does anyone of you know some place to buy them?
Thanks in advance..
Chris
Hi Chris,
I am not familiar with the history of Dale/Resista resistors but if Resista was sold to Vishay then could it be that Vishay's current CMF55 series is what you are looking for? It that is the case then they can be bought e.g. from Mouser or Digikey or Arrow:
https://www.arrow.com/en/products/search?cat=&q=cmf55&r=true
Through Hole Resistors | Resistors | DigiKey
cmf55 Metal Film Resistors - Through Hole | Mouser Denmark
However, if you will allow me to make a comment on this ... resistor distortion drops appr. 6 dBs per doubling of wattage and if the resistors you need are for audio circuitries the CMF65 (or RN65) "E" types have very low distortion. It is also my experience that they are more transparent, dynamic, and open than the CMF55.
But it of course depends on your preferences and use.
Jesper
Hi Jesper
Thank you Very much for your help..
Arrow has only Resistors with VAUES no one uses -
And Mouser has no stock .. must be ordered, but Vishay itself is run out of Stock as well ..
Same counts for Digikey..
These companies should revise the Entries on their websites.
Fact is that ther aint any - Nevermind what DALE Series on the market anymore..
Check the pics I added..
Regards Chris
Have no issues buying them at the formerly farenell.com a.k.a newark.com now avnet (https://www.newark.com/search?st=cmf55) Also convenient mouser.com, digikey.com a bit more pricey.
Also note Dale RN/RL are the same resistors - military spec with dissipation rating lowered so that CMF55 = RN50
Hi Chris,
As far as I can see the CMF55 4.75k is in stock at Mouser. Now I don't know if there are specific restrictions on what you can buy in Switzerland but I normally search and buy on Mouser's/Digikey's default webpages (re-directed to the .dk subpage) and here the selection is full. FYI the page where you can see that the 4.75k is in stock both with Mouser and Digikey:
cmf55 Vishay 4.75 kOhms Metal Film Resistors - Through Hole | Mouser Denmark
Jesper
Hi Jesper
sorry to respond so late was working on my Class A Amp..
I just went through the Denmark Mouser Site and searched for 50K/ Outcome Not available..and exactly the same way it is for many others. you see my problem is, that I don't like to mix resistors.. If cmf56 or whatever type is better or even more expensive.. I do not mind. as long as I can build the Amplifier with just one Brand.
Mixing Resistors has sometime a real bad influence on Sound.
Thank you for searching for me.. I can send a few screenshots ..
I use only .5watt resistors in my Amps, the ones bigger than this are mostly Wirewound becaust thoses ones tend to get hot.
Anyway I will order the one they have at least from each value a 100 pieces..
Thanks again...
Hi
Thanks for the link, that's the way I like it..
just don't get it why Farnell don't have then anymore..
Thank, I'm in your debt..
Regards Chris
Regards Chris
No problem No debt 🙂
Weird eh.. newark IS farnell (avnet now) I don't get that separation either.
Also Instead of 50k you can search for 49k3, 49k9, 50k5, 51k0 values it still within 2%
I was looking at the RN60 offerings at Mouser and it seemed to me that they had a number of non-standard non-E-96/192 values. And lots that weren't stocked too.
I find their interface unhelpful so ymmv.
Exactly . the same on Farnell but greyed out..
I need them for my next project.. because as i already wrote I do not like to mix Brands..
Guys you are all just great. thanks for your help..
