Dave's 8" woofer + 104mm tweeter speaker build
Dave -
I wished I would have remembered that I offered up the name "Sea Waves" in post #4, I would have charged you a royalty of 10 minutes of advice on woodworking. Your craftsmanship is amazing!
I concur with others, I thought your speakers sounded good. Whether they were in fact a little bright or not, I'm not sure but I did get that impression during the competition round when they played. (But not to the extend that they sounded "bad" due to the brightness, just that they seemed bright relative to one or two others in the group.) Most of the speakers differed in pretty minor ways, so it could easily be that yours played between two speakers that were a little more laid back and thus they "appeared" bright. Where people were seated also made a big difference. Friday night someone's theme speakers played and I thought they sounded pretty good, I was standing in the back behind the last row of seats to the side of the video camera on the tripod. Thus, my ears were probably 2.5 feet above tweeter level and there were probably 20 people sitting in the chairs between the speaker and me absorbing/blocking some of the upper frequencies. For the competition, I sat around the 5th row and more towards the middle. Those same speakers seemed too forward relative to the others playing in the same group.
Reactions: mordikai
The slight brightness I referred to is definitely well within the range of voicing personal preference. Probably program material dependent as well. For most pop music, I prefer a -4 dB slope from 100 to 10k... and this is the kind of music used in the competition. For most jazz and classical I prefer a more flat response from 100 to 10k, and this is where i thought Dave's speakers were... Again, just my preference, and I really liked those speakers.
j.
With the PR weights all decided on, it was time to build the XO's, install them, wire up the drivers, button everything up and hope they met my expectations!
I am very pleased with how they turned out and sound!
Is zobel network for woofer missing by purpose? It can help to reduce response in cone breakup region, match phases better and to get little better total speaker impedance.
Dave these look and sound fantastic. I don't vote due to my very poor listening position (behind the speakers running the gear) but when I heard them prior to the theme portion, I really liked them. Cabinet design and construction are things to be nearly jealous of here and the crossover design is very good. Honestly if they might have been in with others, they might have won the round. It was quite close in voting.
Excellent work and craftsmanship - I especially like the thorough approach with the spin table 👍
When making filters, I find that I get a smoother response and sound when correcting the shelf of the upper response of the mid-woofer - in this case - at 2500-3500Hz, where you see the response plateau before it continue to dive. It seems to match the beginning break-up of the woofer, which IME is also a good thing to tame. Thoughts?
