Denon PMA-1560 defective circuit
Hello everyone! I got this from a friend of mine, It doesn't works. I opened it I founded there were three burned resistors. So, I replaced them, but when I turned on the amp, they broke again. I found the schematics on the web and I started studying it and testing some components.
I uploaded the scheme with marked the problem that I've.
In red R531, R537, R539 the three resistors that I found burned. I tested the outputs from the main power unit (circled in green), they should be +/- 66.4 V, mine are +/- 72.3.
Now... I don't know where the problem is. Probably the toroidal trans? or the four capacitors? I'm not so expert.
Can somebody help me?
I replaced TR511, TR509, TR513 and TR517, nothing changed. Could be something between the three resistors? And I forgot to say that even on the other amplifier I found burned the same exact resistors.
