Might I remind you, I'm now retired, and have all the necessary equipment I'll ever need these days.If 400$ is expensive, you should stop building tube amplifiers 🙂 I could schitt 400$ with DIY these days.
As for cost, it's not a big priority for me to have something like that.
I did my duty for decades, hustling around the service shop.
Over it.
+10 on keeping the Hakko cleaned: It's not hard to do, but do it frequently Empty it of solder as needed and run the cleaning wire down the opening often.
ok thanks for the advice guys, it does seem like what i need, im happy to invest if it does the job👍
Years age I did use something similar to this was made by weller .... was quite good ...
https://www.amazon.com/RadioShack-45-Watt-Desoldering-Iron/dp/B007Z7MNEM
But there is a trick ..... do not squeeze the rubber bulb for no reason .... squeeze the bulb once & hold it ! apply desoldering iron until solder is melted then realease the bulb ... ... & .... clean the tip frequently ... and swith off after use ....
Congratulations! I wonder how I ever got along with out it each time i use it - which is often.
Hal
Also, I agree on needing the rain; I gather you are near Atlanta - I'm in NE Alabama and I, and especially my yard, feel your pain.I brought a Hakko FR-301 in the end, and it's a gem of a piece of kit. Love it
Hal
- Design & Build
- Equipment & Tools
- desoldering station/pump for lead solder
