Got my first PCBs from ITEADstudio today.
There was 12 pieces instead of the promised 10![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Looks perfect.
3 weeks from order to arrival in DK ... not bad at all![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
With regards to cut out information, ITEADstudio want this information on a Mechanical layer .... seems like the right way to do things![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
... now I just need to order some components from Digikey to be flying![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Looks perfect.
It cost 10 usd for 10 boards 5x5cm at ITEADstudio.
It took 3 weeks from order until I received the boards.
Here is a good list of PCB SW https://www.olimex.com/PCB/DesignTools/
I use a very old PCB SW, because I have gotten used to this SW ... think there are many good FreeWare options today ... Eagle has a light version limited to 10x8cm boards that many uses ... KiCad looks nice ...
They have other sizes like 10x10 cm for 24 USD .... see list here
PCB prototyping
Have some black 9x5 cm, 2 layer bords in order![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
At some point I will have to try 4 layer .... gives some very good possibilities for unbroken GND layer and better layout of supply voltages
PCB prototyping
By any chance did you select board dimensions from the "Sick of Beige" standard PWB sizes? (See < http://dangerousprototypes.com/docs/Sick_of_Beige_standard_PCB_sizes_v1.0 >.)Got my latest boards from ITEADstudio today ..... look really good I think![]()
Dale
Why is this in Class D?
![cop :cop: :cop:](https://files.diyaudio.com/forums/images/smilies/cop.gif)
By any chance did you select board dimensions from the "Sick of Beige" standard PWB sizes? (See < Sick of Beige standard PCB sizes v1.0 - DP >.)
Dale
No, they just look like it as I wanted to try out the rounded corners to see the capabilities of the manufactor .... and they are perfect
- Design & Build
- Parts
- Dirt cheap prototype PCB manufactory
