DIY D1 I/V Stage from Pass Dac PCBs for sale
I am just about to start building these boards and have a question about the output filter and series resistor. The CR high pass filter created with the 4.7 uf cap and 100k resistor to ground should give a corner frequency of .3 Hz. I wanted to change this to 10k to ground and 2uf cap, which should give an 8 Hz f3. The 2uf cap is cheaper.
However, does the 220 Ohm series resistor have to be incorporated into the equation? It looks like a voltage divider in reverse but I'm not sure if it actually behaves as one. My guess is that it does not. Any thoughts?
