We need a consise set of calcs
After seeing what Marklar did i think the thread would benefit by a very good rundown of the calcs that he did and how they were used.
I have a basic understanding of focal lengths, but like a lot of us dont really know enough.....i've read all 2K posts so don't say read them..
Specifically, can anyone tell me what calc Marklar used to find the dist between his light source (it has a focal length right and a lens right) and the fresnel/lcd......but more importantly how to do the distance between the lcd and lens and wall. What size aperature of this lens is necessary? I plan on using a lens that has a small aperature (35mm SLR).....if someone can give me a good set of calcs and what numbers are important it would be appreciated.
I already have an LCD/OHP, but would like the quality that Marklar's design has........i just dont know what calcs were done for bulb/light source placement.......what determined where in the reflector the bulb goes, where the lens in the reflector goes, and how far from the fresnel/lcd the light source goes.
COOLING IDEA
allcorp has a thermoelectric cooling unit it's like miniture refrigirator it can produce cold temperture up to 68C in a small area this is great those metal halide bulbs it cost 26.00 at www.allcorp.com
I don't need this because i'm using a compact flouresent bulb from lights of america that puts out 3700 lumens. If you go to www.topbulbs.com they a compact flouresent light bulb that puts out 12000 lumens put it's 11 inches long.
TEC (thermoelectric cooling) is nice, but its HIGHLY unpractical, unless you are super cooling. you can really only cool point ot source with it. large surface area is really hard to do.
seconldy, they have MASSIVE condensation issues, so it has to be fully insulated, becuase you dont want moisture inside the projector.
lastly, they get cold, but they also get equally hot... i had a medium power heatsink/fan on one once, and it burned up in less than 30 seconds. you need to REALLY cool these things. and, that creates noise, but you have to get the heat OUT too. and powering them isn't the easiest task. they take a lot of power.
the thing is, we dont need something like that for this application. a fan will be FINE. just make sure its a GOOD one. i suggest a panaflo (panasonic). i have some that push around 60CFM each an operate silently. you can boost the power up a bit, and get 87cfm from them, and they are still barely audible. i used them to cool a radiator for watercooling.
quality, not quantity. a CPU in a computer gets in the hundreds of degrees C within seconds if not properly cooled. our projectors dont come close to that... and hell, we can cool the chips with just a heatsink and fan, as long as we dont expect amazing temps.
if a CPU can operate like that, i think our stuff can too.
rmccoll said:COOLING IDEA
Yeah, TECs are nice, but not for this app....they draw a ton of power, and they have to dump the power somewhere.......they get awfully hot and require a huge heatsink wich requires something to cool it. Our MH bulbs have too much surface area to even think of placing these on them.....not to mention you couldnt evenly distribute the cooling properties resulting in hot and cold spots wich would most likely cause the glass to crack from the thermal stress
Answers!
Well let me say this dont build a projector based off of mine, it is nice but it needs tweaking. As for how I got my distances I didnt use any math I just layed everything out on a table and moved everything around untill it looked good. Math cant tell you if your gonna have a hot spot so you just have to play with it. I have also thought about using something to block the lcd when I want to watch wide screen but i have a nice da-lite pull down screen so i just pull it down to where it reaches the bottom of the image and Im gonna put a black cloth at the top to absorb that light. I tell you what Behind enemy lines was awsome in letter box the fighter jet part owned on the big screen
. I can watch it during the day but I have to close the blinds. well thats all for now got any questions?
Marklar question
Marklar, what type of lens did you use at the opening of the light source? Is that just sheet metal with a lens on it? Also can you explain how you decided where in the reflector to place the bulb? I dont quite understand what you said by putting your finger in and looking for flesh color.....I'm not copying your design...I plan on modifying it signifigantly, but need to understand yours better first
LCD Monitor Panels...
Hi Guys,
Here's a whacky idea that might be of interest to those people with LCD monitors and Laptop Panels...
Would it be feasible to remove the CCFL Panel backlight and replace it with an "apparatus" that used an elliptical reflector surrounding either a 300 Watt double-ended halogen ("Torchiere" variety), or a high power fluorescent along the lines of the 11" LOA-style offerings mentioned above?
The halogen option would need an IR filter and excessive cooling in order not to melt the LCD, and all options would need some kind of long thin cylinder lens (possibly the cheap plastic type available for magnifying sections of pages).
The idea is that these panels already have a very efficient mechanism in place to give a uniform distribution of available light to all points on the LCD surface, and also to get that light to come out from the front of the panel.
Gunawan has already ratified that I am not criminally insane for suggesting the use of a fresnel in front of an LCD panel to collect all of the emerging light and focus it on the main objective.
If we could utilise the existing efficient mechanisms in a LCD monitor, but using a more powerful light source, we could produce a nice, compact hi-res projector...
Thoughts, anyone???
Bill.
Hi Guys,
Thoughts, anyone???
Bill.
laptop panels
i think it nas been previously discussed that these(laptop) panels have the potential to be our ideal image source. the problem is getting controller boards for them at a reasonable price. check outearth lcd we're talkig $300-$400 for the setup. I'm hoping to find something a little less costly. if anyone can find a small( under 10") lcd monitor for less than $300 that would be perfect, as long as the controller, inverter, backlight can be easily removed from the light path.
re: LCD monitor
we can use the lcd monitor, but i prefer to use a panel, because a panel is a lot smaller and is made for projection. and in any case you will HAVE to use some type of objectives to project the image. that will add whatever the focal length of the lens is to the length of a projector. BUt i am working on a new design that will cut projector size by a good 1/3. tell you later, gotta go.
aleksey![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
aleksey
Re: Laptop Panels
Hi Guys,
Good stuff! I was actually thinking here about using a laptop panel directly connected to a laptop - my primary DVD player IS my laptop.
It gives me progressive video at the 24fps of the original film, while automatically scaling up the video resolution to match the screen.
For many laptops, a second LCD panel can be bought fairly cheaply, and the idea of being able to wire my laptop into a secondary screen that was driven by a much brighter light source than the standard CCFL tube is interesting.
A standard LCD monitor is a more flexible, but possibly more expensive alternative.
The technical question is whether the issues of trying to remove the back of the monitor panel, performing micro-soldering to extend the ribbons, and then building a massive light enclosure to get even lighting across the back of the LCD, can all be avoided by "squirting" a high brightness light source down the normal light path that the panel's standard edge light would use...
In effect, it would bethe equivalent of turning up the brightness of a standard LCD monitor (or laptop panel) by a factor of 100 (guessing here) and using that light source with a fresnel and suitable objective to project an image.
Bill.
Hi Guys,
Bill.
noodles
i like your idea with the aspect boards. getting rid of some of that extra uneeded light can help the projected picture look better to the eye, sharper apperance,& i think it looks like it changes the contrast to(i did some tests with some like that when i first started trying to get my tv to project a picture on the wall).also i dont no to much on this but im guessing it might help with blurry edge's on the projected picture.
i was trying to find out how to make a setup where i would have all the aspect boards attached in one unit,you just answered that so thanks.
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Re: Marklar question
Yes I just robbed the lens that was in front of the light that was on the dukane 680. with the reflector I put my finger in the hole where the bulb goes and looked stright at the reflector and it reflects my finger on the sides of the reflector when my finger was at the focal point. My projecion lens is 327mm right now but Im going to get a 450mm so I can move my screen back.
eebasist said:Marklar, what type of lens did you use at the opening of the light source? Is that just sheet metal with a lens on it? Also can you explain how you decided where in the reflector to place the bulb? I dont quite understand what you said by putting your finger in and looking for flesh color.....I'm not copying your design...I plan on modifying it signifigantly, but need to understand yours better first
Aleksey,
The 575W MH bulb is actually quite nice for projection - it has a small spark gap (7mm - much smaller than the standard 400W bulbs) a high colour temp (5600K), and I have seen them for as little as $90 (ish).
It is a small bulb in comparison to the standard 400W modules, and can be mounted (with a little ingenuity) in a parabolic/elliptical reflector without too much difficulty - giving a VERY nicely profiled beam.
Osram now make them with 1000 hour life, but you pay much more for that.
Now the down-side: They are not compatible with the standard 400W ballasts; they require a high voltage igniter; and run very hot. It would appear that they run SO hot that the ballasts (usually electronic) and/or igniters fail prematurely. (I have encountered three dead ballasts in old projection equipment in the last couple of months...)
The ballasts/igniters are a pain to find replacements (or components) for, and those that can be found cost a fortune due to these bulbs being used in photo/film lighting equipment - such stuff costs a fortune...
Despite this, it is my bulb of choice when I can get suitable ballast components to drive it (cannibalised from DOA old projectors...)
If you have a system that uses such a bulb, and it is in good working order, then you are in luck! Treat it nicely and Enjoy!!!
Bill.
P.S. Forgot to mention the most important point: an output of 49000 Lumens...
Bill.
sharp panel
I got a sharp qa-1650 off of ebay- purchased beginning of May.
I asked to have it shipped to my sister's place in the US so she could bring it when she came to visit (I live in canada and wanted to save on shipping-he quoted me $90 shipping to Canada-$20 to US). Because the guy didn't ship it until over 2 weeks after he said he would, it did not arrive at my sisters on time for her to bring it. Also, she didn't feel comfortable testing it other than to say it powered up ok. She came up to Canada again today so I could finally test it.
Unfortunately, the VGA input doesn't seem to work, and with the rca video in I only get black and white images from a DVD or VCR.
Im tried all settings from the panel and the remote (ie contrast tint color), but still only get black and white. Haven't tried s-video in yet-will buy a cable tomorrow.
Any suggestions as to what could be wrong?
The weird thing is that the startup screen appears in color and all colors are crisp. The menu is in blue and thats ok too. But screen only shows black and white???
Hope someone can help me. I'm not counting on the seller being very supportive- he never returned emails when I was trying to find out why my panel hadn't arrived when it was supposed to.
Thanks.
Thanks.
hmmmmmmm
i am afraid that my 600W ballast will give up on me and i will be left with a broken projector. i know that 575W MH bulb is buyable for $70, but if the ballast fails, i will be in deep touble.
also you know how in dukane quantum 680, the bulb is housed in between a reflector and a condenser lens, and the whole assembly is quite small. and the fact that they recommend changing the bulb after 750 hours, doesn't mean you have to.
so here we have. up and downs of 575W.
UPS:
small
is housed with reflector and condenser
49000 lumens
nice color
downs:
short life
expensive
it is kind of balanced.
also the 400W bulb gives off blue end of the spectrum, so it may display colors not as bright as they are supposed to be. and that thing is huge, i've seen it yesterday. if i put it in my projector, it will,be huge.
my main objective now is to decrease the size of the assembly, i wanna make mine about two times smaller than marklar's. no offence of course, but i think that we have spent a lot of time here and we have come to a STALL. i do not see a good alternative for a projection panel, so i will use it in my setup, but i will work towards making my design smaller. i will probably have a fold-away design for the objectives. also i am working out a design that will let me cut the focal length of the objectives i have right now with mirrors. it is a bit tricky, but if it works, it will decrease my projector's length by about, say 9", that's a lot.
also i am going to try to take the panel apart and detach the LCD screen form it. if i succeed, i will have a projector way smaller in a diagonal size than any of the ones made until today. DIY of course.
and now i have a question... do you think that i will break the panel if i try to take it apart? consider the fact that i am very handy and cautious.
because having to deal with a 10.4" screen is a lot easier than dealing with a 18" panel ( that's what i have)
and i am planning to get Shapr QA-1800 during the weekend. of course for a reasonable price only. that thing has nice contrast, pallette, and inputs. i hope it will serve me well, if i get it , wish me luck.
thanks...
aleksey![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
UPS:
small
49000 lumens
nice color
downs:
short life
expensive
thanks...
aleksey
woneill,
as I mentioned before, there was no distortion on projected image, the image in perfect shape.
Distorsion came up when I looked directly in front of the fresnel panel, like using magnifiying glass.
The problem was, when I placed fresnel closed to the LCD panel (in my case = transparancy), it showed up moire effect. If I moved further away, the image became to big.
I don't know the benefit of this setup, maybe we can get
sharper image with less "lumens" light, maybe it will eliminate hotspot problem with big size LCD panel, if the result will make worsen image, then I will back to earlier setup.
Guys, who own 2 fresnel panel, can you make a test to confirm this setup? Please...
marklar,
you can use mirror to bend light 90 degrees, make sure using front surface mirror.
Actually I have similar plan. I will use hanging cabinet (cupboard?) behind my sofa.
The setup goes like this:
On top is Lamp housing facing downward, next is fresnel then LCD panel, before the beam hit the bottom of cabinet, I will place adjustable mirror to bend the beam 90 degrees to the cabinet door. The mirror also can use as keystone correction too.
Last, I will place the lens set (with zoom adjusment) at the cabinet door.
From the outside, you just see a hole with the lens set (around 3" diameter) at the cabinet door!
see you.
marklar,
see you.
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- DIY Video Projector Part II
