Maybe use an external supply initially to test the circuit, while disconnecting the old caps for reforming.
The problem is, I can’t envision myself disassembling an entire amplifier to reform every capacitor. If I go to that length, I might only attempt to reform the large main supply capacitors - everything else would get replaced. Even old Black Gates, I would probably replace them with modern Panasonics or Nichicons with appropriate ripple current ratings and “hours @X temperature” specifications.
My unwritten motto has been to replace them. The worst was desoldering them from double-sided boards where there was a solder joint on both sides and both leads needed to be heated simultaneously.
It is a universal problem. For now, I manage with a blower to heat up several leads at the same time, but I plan to buy a desoldering station.The worst was desoldering them from double-sided boards where there was a solder joint on both sides and both leads needed to be heated simultaneously.
In a finished valve amplifier, all valves should be removed before any reforming process, including any valve rectifiers. No sense beating them up by running at low filament temps while Variac'ing. If you do this often, folk make up an octal 5T semicon replacement from an octal base, or you can just tack a pair of 1N4007s on the socket. Be sure to watch unloaded downstream voltages; temporarily add substitute loads if needed.
Strangely, I see most all low voltage old electrolytics, like cathode bypass caps, bad in old gear. No idea why.
All good fortune,
Chris
All good fortune,
Chris
We are getting the house ready for a party this weekend and I’ll have time next week to see what I actually have. I’ll post pix.
I took some money in the past thanks to RIFA caps.That's right, Marcel, and it also holds true for German WIMA Durolit capacitors, even though they carry that trustworthy, triangular VDE symbol.
My experiences with these are just the reason why I keep warning from paper capacitors in general. This is nothing else than an outdated technology.
Best regards!
Several C.R.T t.v sets had come in for repair due to burned fuses+caps.
This is how I paid some of my son's education expenses!
And also, they're not worth bothering to save - really nice replacements are a buck or less. They die from bad ESR.Perhaps depending on how long this gear hadn't been powered?
All good fortune,
Chris
Most of them look OK: transformers, "reactors" (inductors), except maybe for the rubber-insulated wires which will probably be embrittled, the wirewound resistors are like new, quite a good lot
Ah, those are resisters??? I have a box of 9 of them. As I go through most boxes, I’ll post more pix.
In fact, what I mistook for WW resistors are inductors, and they are in pristine condition. What are you going to do with them? I don't know. Some Hams would find them useful, bur for audio projects, they are mostly useless. Class D maybe?
This sadly appears to be typical for RIFA's...View attachment 1247927
This is the RIFA cap that fizzled on me last week. The stink takes a long time to clear out.
Best regards!
I've never seen one like the one on the left before. Through the gap it looks like there could be turns underneath. Do all the surface windings/sections have continuity one end of the core to the other? Interesting.In fact, what I mistook for WW resistors are inductors, . . . . . . .
Here's some info on the transformer in the last photo
https://aerobasegroup.com/part-number/m80158-501_00-645-0755
Just Google the manufacturer and their drawing number
No, not necessarily: some need to be fully insulated from the rest; it all depends on the applicationI've never seen one like the one on the left before. Through the gap it looks like there could be turns underneath. Do all the surface windings/sections have continuity one end of the core to the other? Interesting.
- Tubes / Valves
- Do capacitors go bad if they are not used?
