Hi George,
Do we know anyone having acces to this Machine.
It is cited frequently that the tip transfers heat to the cantilever and from there into the air, which may be true, but the question is how much?
A Boron cantilever has a heat transfer ratio of 2.7 W/(m.k), for the epoxy bonding even as low as 0.14 W/(m.k) against the super heat transfer ratio of 2200 W/(m.k) for the diamond tip.
So this machine that you mention could measure in one go the tip temp, the groove temp and the cantilever temp.
That could clarify a lot.
Hans
Hans
Also interesting to know is that high temp Epoxy starts losing its strength at ca 200C and completely desintegrates at 300C.
With figures of 160C tip temp that some mention while playing 33 1/3 LP’s, it’s already very close to the 200C.
But when playing at 45rpm or even worse at 78rpm, thereby generating proportionally more frictional power turned into heat, would mean that you are facing the risk of a tip separating from the cantilever.
I’ve never heard this to happen.
Hans
Hans
Hi Chris,An especially annoying aspect of the AES is their indifference in keeping information available. They seem to want to die with it clutched to their bosoms. For example:
https://www.lathetrolls.com/viewtopic.php?t=796
It's classic old guy behavior and not flattering to us old guys.
All good fortune,
Chris
A lot of Interesting info’s
Thx.
Hans
Hi hansHi George,
I've deliberately burned all my bridges with the past
I don't know if you can contact any dealer for short time leasing.
Not in one go. The numbers will be wrong. I mentioned the way to do it properly in post #49So this machine that you mention could measure in one go the tip temp, the groove temp and the cantilever temp
George
Don't think about it. Try touching the tip with a sensitive finger. Anything close to 50 C will be detected.With figures of 160C tip temp that some mention
For the record, I had two tip separations but none was due to heat disintegration of the epoxy (tested under microscope)would mean that you are facing the risk of a tip separating from the cantilever.
Hans
George
All fascinating.
BUT.. I recently inherited a Large(ish ) collection of Lps.
Most all of which were New/sealed /never removed form their sleeves, let alone played.
Directly compared to My Original and lightly played Exact same Lps.. The sounds.. on the new Lps ( thorens and a Microline stylus) .
Are Markedly .. instantly apparent.. Better sounding... a lot better.
More Sparkle, range and presence in their playback.
Very nice and gives genuine appreciation of the actual sound qualities in a simple Vinyl LP.
Also.. an instant reminder of what was clearly obvious /generally accepted knowledge in the 60's /70's ;
LPs deteriorate audibly by their 6 to 8th playback.. Period.
NO amount of analysis sophisticated 'after the fact' alters that reality.
I found this sound quality degradation thru use.. to be absolutely true, at least to MY ears.
I would say by their 666th playback. Aperiodic.LPs deteriorate audibly by their 6 to 8th playback.. Period.
George
My experience with brand new discs has been that they often have huge amount of static electricity buildup on them and in case of paper sleeves, dust from it caused by motion+friction during transport. That static electricity holds that dust quite well on the disc and it takes some effort to get rid of it, and if one was to play that disc one will find that it is noisier and cracklier than it should be but after a few plays this normalizes as the stylus mechanically picks up the paper fluff from the grooves and helps to dissipate that surface charge lol.
Very interesting thread, I had great pleasure reading through it ~
If we look at mechanical bearing technology, one always tries to avoid “metal-to-metal” or metal to hard crystal contact. Hence, lubricants provide a thin film of oil or wax that prevents actual metal-to-metal contact. When one of the surfaces is a hard plastic such as “Delrin” a type of nylon - then liquid lubricants are not needed as it is self lubricated because the plastic is not hard and will not damage the metal. Has someone tried playing diamond stylus on steel with oil lubricant?
A vinyl LP and diamond stylus is much like a delrin/steel bearing.
The pressure is set to not cause plastic deformation. That would ruin the LP.
Ice skate blades on ice is a perfect example of metal to crystal with a liquid bearing surface of water. There is no metal-crystal contact when working properly as the blade floats on a film of water generated from pressure melting of ice. Pressure applied to ice causes interface contact point to convert from solid to liquid. The ice skate is literally like a boat floating across a pond of water. Albeit, a very skinny thin boat and shallow pond. Hence, this is why ice is so slippery when a hard smooth surface is pressed on it. This is well known.
I think the reason people don’t use steel LP’s with oil is that it is plain messy and makes the whole audio experience smell and look like an auto-mechanics garage or shop.
It were also my initial thoughts that while skating, the pressure forms a layer of water.
However, pressure is too low to achieve that.
What really seems to happen is that a layer of “smurry” and not water is formed under the skate.
https://www.vox.com/science-and-health/2018/2/13/16973886/why-is-ice-slippery
Hans
Hans
So you say, but I disagree, and Walton in the 60s disagreed as wellLPs deteriorate audibly by their 6 to 8th playback.. Period.
go away science, my ears and beliefs are all I need and you must believe me!NO amount of analysis sophisticated 'after the fact' alters that reality.
About 30 minutes in Franc Kuzma talks about taking a 50 pound platter with a air bearing, spinning it up by hand to approximately 33 rpm (without belt) and waiting 30 hours for it to stop
He puts a record on, spins it up again to 33ish rpm and puts a stylus in the groove and the platter stops in 10 minutes
not scientific per say, but stylus friction none the less
those turntable, tonearm, cartridge freaks that have not listened to this interview should, lots of good info on how one of the masters sees things
All the energy in the system comes from the TT platter so we have to consider the energy required to move the cantilever/magnet/iron regardless of anything 'lost' due to friction in the stylus contact with the groove. Also I guess, the energy required to move arm bearings too.not scientific per say, but stylus friction none the less
Interesting none the less. The idea of this 50kg (it is 50kg and not 50lb) platter continuing to rotate for 30h is pretty mind boggling, but then there's a lot of energy in a 50kg chunk of metal rotating at 33rpm. I've used a hand pedalled potters wheel, and they're a right b*****d to stop once they're up to speed.
There's actually remarkably little energy in a 50kg platter spinning slowly at 33rpm, about 5 joules, about enough to lift itself a measily 1cm. Spin it at 3300rpm and its got the energy to lift itself 100 metres!!
5J dissipated in 30 hours is about 50µW of power on average lost to viscous friction, whereas the stylus pulls more like 8mW out of the system to slow it in 10 minutes, which makes sense as the groove velocity is about 0.4m/s, force = power/velocity = 20mN (about 2 grams force, part sliding friction and partly power to drive the oscillation of the stylus assembly)
- Analogue Source
- Effect of Stylus friction on LP
