Equivalents to 2SD1763A and 2SB1186A
Hi Folks.
I am trying to clone the JBL powered sub to go with my new LSR25 speakers, and am having a problem sourcing the above devices, made by Rohm.
Google search gives me nowhere in the UK that stocks them, so I was wondering if anyone knows of equivalents, or has datasheets for them so I can go for a search myself.
Would MJE1530/1 work, I have loads of them? 🙂
Hi, Pinkmouse
2SD1763A: NF-E, 160/160V, 1,5A, 20W, 80MHz
2SB1186A: NF-E, 120V, 1,5A, 20W, 50MHz
Both are listed as complementary parts.
You could replace the with:
2SD1763A: 2SC3298(A,B), 2SC4159, 2SC4370, 2SC4883A
2SB1186A: 2SA1306(A,B), 2SA1332, 2SA1606
MJE15030: NF-L, 150/150V, 8A, 50W, >30MHz
MJE15031: NF-L, 150/150V, 8A, 50W, >30MHz
Datasheets for MJE15030/1:
http://www.onsemi.com/site/products/summary/0,4450,MJE15030,00.html
Here's data for the 2SC4159/2SA1606:
http://service.semic.sanyo.co.jp/semi/ds_pdf_e/2SA1606.pdf
And here for the 2SC4883A and the 2SA1859A which are complementary too:
http://www.sanken-ele.co.jp/CGI/en/...name=2sc4883ae.pdf&s_name=2SC4883A&gen_big=TR
and
http://www.sanken-ele.co.jp/CGI/en/...name=2sa1859ae.pdf&s_name=2SA1859A&gen_big=TR
/Hugo
Thanks for that Hugo :up:
Unfortunately I can't seem to get any of those in quantities of less than 200, the usual small order suppliers such as RS, Farnell and Rapid don't seem to stock the Sanyo parts 🙁
I will keep searching for the Sankens though, and looking at the Onsemi website, the MJE15032/2 looks a bit closer in spec as well. More research needed I think!
Netlist said:
I can get you the original parts (2SD1763A, 2SB1186A) if you want, in small (one or more) quantities.
Thanks for your offer, but after about 6 hours fruitless searching it seems that getting just about any Japanese transistors in the UK is just about impossible, I might have to put this project on hold as I can't get any of the small signal ones either.🙁
It's a shame 'cos it looks like an interesting amp, with split supply rails, and an interesting front end, a good learning project.
Oh well, back to the drawing board!
