yep, last step towards unleashing the power of this device, and it really is quite a lot of power there. particularly towards integration/automation. yeah like I said, as far as the DS goes thats the most comprehensively covered area. I guess we'll see where this goes, perhaps now that it can be requested by anyone who asks nicely it will effectively be made 'public' anyway.
Issue with Sabre I2S Interface?
So far I have collected 6 reports regarding having issues with the I2S interface of the Sabre DAC:
1. Hiface Evo
2. TPA USB board based on the PCM2707 chip
3. Musiland MINI, based on Spartan FPGA
4. Teralink-X2 based on TENOR TE7022L and 1ppm TCXO
5. AudioGD ESS DAC
6. "Manufacturer X" converting I2S into SPDIF before feeding the DAC
More info here: Musiland MINI I2S to Buffalo II DAC H I F I D U I N O
The workaround seems to be increasing the DPLL bandwidth, although there is a report of having problems even at MAX dpll bandwidth. The other solution is to use the spdif interface which works fine at lowest dpll bandwidth.
It would be nice to get to the bottom of this. Any ideas?
1. Hiface Evo
5. AudioGD ESS DAC
1. Hiface Evo
5. AudioGD ESS DAC
With the Sabre32 DAC I can run the minimum DPLL bandwidth with 192k/24bit on SPDIF and 352.8k/32bit on I2S.
I do not know what "the" problem are, but I use the Sabre32 in Sabre32 modus and pinout.
Uses the SPDIF mux on DATA6, 7 and 8.
Uses the I2S with SPDIF disabled on DATA2, 3, 4 and 5.
Uses a 98.304MHz clock with less than 0.5ps jitter.
Uses JFET regulators etc...
Only the "000 No bandwidth" setting are not working, but I am not sure if it should work at the input rates I use or at all for that matter???
I can use all internal settings like normal/50k/60k/70k/slow/fast/OSF disable/enabled / quantizer 6/7/8/9bit etc...
Thus I would not expect that there are any internal causes to the problems as I have no DPLL issues with any internal settings.
I honestly have never had any trouble with any clean I2S source keeping a lock on the lowest DPLL setting at any bit depth or sample rate. You do have to be very careful about the signal routing and GND returns. Even with the PCM2707 I don't have any issues.
I am not saying there may not be some issue, but if there it it is likely not the fault of the chip. More likely to find the problem looking at more basic design concerns.
Having thousands of working DACs out there I have only heard a handful of issue regarding I2S, and most of those were solved by simply using better routing and paying attention to GND return.
So not sure where you want to take the discussion. From a DIY perspective it is easy enough to use what ever DPLL BW you see fit.
RayCtech, thanks for sharing.
Based on your description, you can connect 3 spdif sources and 1 i2s source and select them in s/w? That's pretty cool.
Hi Russ,
Just curiosity from a "technical mind" as more reports keep popping up, nothing "evil"![]()
No I would never think such. But I am just saying it is definitely not a common problem as far as I am aware.
- Digital Line Level
- ESS Sabre Reference DAC (8-channel)
