thk's all,
dac input type includeing i2s/dsd/spdif,sampling rate to be obtained through registers.
Can you please re-upload the file? Thank you
Will put the contents in my dropbox for a few days: https://www.dropbox.com/scl/fo/ezsw...P_JTOpzo?rlkey=m5ymbqndaxn6dhxxans1oci4i&dl=0
If you want to edit the design files at all, IIUC they used Diptrace to design the board. If you install the free trial of that then you could make some changes.
I downloaded those files, but the schematic file is in a format that diptrace didn´t open. 😵
Since I use KICAD I tried to open or import the files here also.
It seemed to work with the layout, but again not with the schem-file.
Anyway, is there a short description in this long thread, that basically sums up what is needed to build or buy a 8-channel DAC with USB Input?
I´d like to do the speaker management with Xover, EQ and room correction on my music server utilizing Accourate software and then sending it to an 6-, or 8-channel DAC.
jauu
Calvin
jauu
Calvin
Short answer might be (1) you could by a commercial 8-channel recording interface, or (2) you could make a diy 6 or 8-channel dac.
For the second option you would need to make a dac board, and maybe buy an 8-channel USB board from diyinhk.com
If you want to make your own dac then probably ES90x8PRO would probably not be the best choice. The newer ES9039 parts are reputed to sound better. Or you might choose to use 4 of AK4493S stereo dac chips. Something like that. In any case, its probably questionable whether evaluation board designs are optimal.
Also, if you have not designed a dac before there may be some learning curve. Not really any good Doug Self or Bob Cordell type books for that (despite Cordell's latest effort).
I am also interested in how to calculate the sample rate from the registers of the ES9039 chip (PRO, Q2M) via the I2C bus, indeed in previous ES9028,38 versions there was a DPLL_NUM, it was simple, in the new version it is not. Perhaps there is another non-explicit way to determine SR by I2C from ES9039 chips (PRO, Q2M)?you can give an example?
DPLL_NUM is a ess9038 register,and now we focusing on ESS9039.
ESS9039 does not have DPLL_NUM.
You use microcontroller (MCU) to read the registers?
Why not to use the same MCU also to measure the sample rate?
It is usually very easy.
Alex.
I use the I2S bus (for PCM/DSD) as a transport, I don't think the 136+251 SPDIF will help me, but I'll try to work with it, thanksHave you tried what I suggested in post #2720?
Alex.
Yes, I'm still using the ATmega328 MCU for testing ES9039Q2M. Do you suggest making a Serial Clock (SCK) I2S bus frequency meter by MCU and converting it to a Sample Rate?
What is your source? Don't you know the sample rate it uses?I use the I2S bus (for PCM/DSD) as a transport, I don't think the 136+251 SPDIF will help me, but I'll try to work with it, thanks
The source is the Amanero board, I can use its pins to determine SR (Sample Rate current soundtrack), but I wanted to determine SR using the I2C bus from the ES9039 registers, as it turned out, this is a problem. I haven't checked the 136+251 SPDIF registers yet.
Sorry, I misunderstood your requirement. I don't think SPDIF registers will work in this case. With I2S/DSD input the source (Amanero in this case) is the easiest way to determine the sample rate. But Altor's suggestion works as well although it involves more work.
Yes, I always do this - I measure the BCLK frequency and make a decision about SR depending on the PCM/DSD signal.Do you suggest making a Serial Clock (SCK) I2S bus frequency meter by MCU and converting it to a Sample Rate?
If DSD is not required, you can measure the WCLK frequency.
I did this on STM32L1xxx and PIC16F819, I'm sure it will work fine with ATMega too.I'm still using the ATmega328 MCU
Alex.
Hello,
Has anyone looked into the recommended approach for combining output channels found in the ES9017 datasheet?
If I'm understanding this correctly, for the ES9039PRO in 2-channel (stereo) output mode, channels 3/4/7/8 need to be inverted by setting register 87, and then the channels are to be combined in anti-phase like this?
- Digital Line Level
- ESS Sabre Reference DAC (8-channel)
