Fake STK3152/STK3102
Hello!
I own a PM80 SE that has a failed STK3152 that replaced an already failed 3102 around 15 years ago. It's an insane coincidence that David created a replacement just before I was in need for a repair.
A friend and I ordered a few boards made with David's design from China which will arrive next week presumably. I will take pictures and report if and how well it works!
The replacement is working and producing great sound!
Pics:
I didn't think about the thickness when I ordered the pcb. Now I would order it definitely in 1mm or thinner.
The STK that was in it had a heatsink merged with the pcb.
Maybe in a few years it blows again then I'll optimize the heatsink :D So far it's been running day and night
This is the latest KiCad 5.1.0 generated version.
I see what happened, KiCad has changed the Gerber file names slightly and I mixed a version.
The circuit is unchanged, I have just cleaned up the tracking a little to improve clearances and maximised copper area on the output devices
  • STK3102_B.zip
I attempted to fix some of the weaknesses of the original module and the fakes. Splitting the high voltage dropper resistor that seemed to degrade into R7/R10 and the higher power output devices should help reliability.
If anything is getting too hot, let me know.
The split is clever. Didn't notice that until you mentioned it.
I honestly doubt it will break down anytime soon by overheating. If that counterfeit lasted for over a decade your design will for sure
