Those were the crimps “only” to make your own wiring harnesses.
I use this silicone jacket wire for internal hookup, super flexible, comes in many different AWG and colors. The 22AWG fits the Molex KK crimps and housings perfectly.
BNTECHGO 22 Gauge Silicone Wire Kit Red Black White Blue and Green Each 30ft 22 AWG Stranded Wire https://www.amazon.com/dp/B06Y5CXVDS/ref=cm_sw_r_cp_api_glc_fabc_rqc0FbP7ZPQPZ
And if you don't want to spring for an actual crimping tool, I have had good luck crimping the Molex pins with a small needle-nose piers, then soldering the crimp. It is a bit tedious, but I am too cheap to buy yet another tool
I used to do that but trust me, the $20 for the tool is totally worth it as the connector quality is superior and it takes 1 minute vs 5min. Also, the solder can wick into the spring loaded clip and ruin the action. If you do DIY enough, and I think you do, one of the best things to get. I have a whole drawer full of crimper tools but the Molex KK and JST ones are the most used. Also the big ones for the spades and loop terminals.
Here is the one for Molex KK
IWISS Open Barrel Terminal Crimper Plier Tool for Molex Style DELPHI AMP TYCO Deutsch Terminals Crimper Open Barrel 24-14 AWG https://www.amazon.com/dp/B07476C1LD/ref=cm_sw_r_cp_api_glc_fabc_C860FbAQSCZ97
Here is JST one:
IWISS SN-01BM Ratchet Crimper AWG28-20 for XH2.54/3.96,PH2.0,PX,JST,Molex Terminal https://www.amazon.com/dp/B019ARWWFY/ref=cm_sw_r_cp_api_glc_fabc_9960FbAM3BCKT?_encoding=UTF8&psc=1
Here is JST one:
Here is JST one:
Did not realize you can get a crimper that works with the Molex stuff so cheap - $16.00 - thanks for the pointer. I had looked at the "real" Molex tool and had sticker shock
This discovery comes after I just finished a preamp project with about 100 Molex pins to crimp!!
So I guess this supply is a tad to much for this amp?
Output Voltage: 2x85Vdc
Max. Output power: 3600W
Hypex Electronics B.V.
/JZ
/JZ
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=402-1002&DocType=SSFor a non soldered joint, I think that looks quite good. It’s a wire-EDM cut cross sectional view. The wire-EDM process puts a rough finish on the cut. Do you have photos of what you expect it to look like if it was correctly done?
Hey folks, free Xmas amp TDA7293 PCB giveaway here.
Xmas Amp - Dibya's TDA7293 by Jhofland
Happy Holidays!
![Santa :santa: :santa:](https://files.diyaudio.com/forums/images/smilies/santa.gif)
Happy Holidays!
For those of you planning on using the All Cee’s PSU board, we found a small error on X116.
All Cee's PSU for Class AB Amp
It’s easily fixable with a solder bridge or simply use R116 pads next to it.
Yep. Completely gas-tight, and with minimal added resistance from the wire-connector interface.Thanks for that link, Casull! Those are nice crimps - basically, the wire and crimp terminal are cold-welded together under the extreme pressure.
- Group Buys
- FH9HVX - Budget Conscious 100w Class AB for Lean Times
