Greetings!
I am going to be using these 3" widerangers for HT surround as well as serious listening ambience:
http://www.madisound.com/catalog/product_info.php?products_id=8305
I am wondering if I should notch the peak in the 10K region - it appears to be fairly significant.
Any thoughts would be greatly appreciated.
And a belated Happy New Year to everybody.
Joined 2003
You're right, it does look fairly significant, and will likely melt your ears 😉.
If I were using this driver, I'd want to cross it to a small tweeter at about 4-5kHz. The Aura NT1 looks like a good candidate for $9.
I want to get away with a single driver with minimal filter - I decided to order the Aura NS3-193-8A1 - more expensive and less efficient than the Peerless, but it has a smaller peak lower down that I don't think will need a notch, and the next one is up at 15 which I think for my needs will be pretty much out of the way.
Joined 2003
sdclc126 said:I want to get away with a single driver with minimal filter - I decided to order the Aura NS3-193-8A1 - more expensive and less efficient than the Peerless, but it has a smaller peak lower down that I don't think will need a notch, and the next one is up at 15 which I think for my needs will be pretty much out of the way.
Hi, wishful thinking, 😉/sreten.
They look almost identical to me, only at different dB levels. But I'm no expert.
Filter can come later if I feel it's needed.
Joined 2003
Looking at the transfer curve you can see exactly what the filter does; it helps flatten the two lumps in the frequency response. The improvement I believe will be fairly significant, though the filter parts could easily end up costing the same amount as the driver itself.
sdclc126 said:Greetings!
I am going to be using these 3" widerangers for .... serious listening ambience:
Well you asked the question, and Zaph does not gild the lily.
🙂/sreten.
Well, this is what Zaph says about the NS3 -
"An exceptionally wide bandwidth driver, with relatively good bass performance and high output for this size. This is one of the very few drivers that "could" be run full range without a filter, though I'd still recommend at least some baffle step compensation."
hi
The baffle step compensation use at least.Let the driver
operate by itsefe. It's excellent to you.
Thanks Thawach -
Well let's see - I'm going to mount these on 3" diameter ABS plumbing pipes, in the back corners of the room, facing upward at a 45 degree angle. The "baffle" will therefore be oval shaped and only maybe 1/4" wider than the driver frame at the center.
The tubes will be filled with sand, leaving the recommended 2-3L of volume, stuffed with polyfill. Given all these unconventional variables, will BSC still be necessary or effective? If so, could somebody possibly recommend the component values?
Later on, when I get a (flat panel
) TV for my bedroom, I plan to make a 3.1 HT system based on these, with more traditional cabinets. Perhaps I'll get more serious about filtering them in this case, but since they'll be supported by a sub I'm again wondering if they'll need any BSC.
Still a dunce with filters...
- Filter for Peerless 830896
