I have been told the new amp will work up to 2 X 85 Vdc ( Sonnya)
I have to correct that.
For the model with two output pairs. Not the one for single output pair.
- Sonny
Schematic is ready... Only i have not finished of the pcb yet. I need a couple more days....If time is with me.. During the Weekend.
Sooo.
I have invested in 18 or 20 M modules and 8 L modules. That makes it what ? 4000eur ? Thankfully only 8 modules are down at this moment. And i haven't counted that they have exploded several times but we managed to fix them.
So with all the power supplies, cases, work and so on im in these modules for 10 000eur... That's nice when you spend all that money and work, and at the end you have no guarantee that was promised...
Well maybe that will change one day we will see.
I think the other reason is that the main transistors are not manufactured any more.
So i will be in search one day for a 6 or 8 replacement modules that can easily be replaced with the M modules with 60-65v
Sooo.
Hi !
How many amplifier modules in the same enclosure ?
Did you build stereo, double/dual mono, single box amplifiers ,
WHAT sort of topology ?
It looks like having more than 2 modules in the same enclosure is very risky.
JMK
6 channel one enclosure.
For an 3 way active setup.
More pictures here
AudioStatus - Finally found some time to finish my home... | Facebook
More pictures here
More pictures here
Wow beautiful construction.
Nope, sadly this is the main one that had issues. I think it will be converted to a 2x L modules because i still have some spares ones.
Do you have common GND for all or some modules in this enclosure, or not ?
What about Earth ? separate from GNDs?
And how many xfos/smps ?
JMK
From what i can see Andrey has been loged in almost every day in this forum, and kept posting to other threads couple days back. But we all can see that this topic makes no interest to him...
Sad thing. Come to the thread, say that everything has ended, no modules will be possible and thats it. Now i have to wait with my dead amplifier for who knows how long.
. No problems after more than 2 years.Hi !
JMK
I have made one box with four modules
Any news?
I also have hmm 3x 2 channel amps that works with no problem, and ll with different setups, one with cheap smps, one with hypex, and the third one with toroidal power supply. Even the first one that i built works fine till this day...
Hi yes...Any news?
We had some work i needed to take care of just like this pcb.
I will post more update during the weekend... This is 1 of 8 pending pcb design.
- Vendor's Bazaar
- First One - mosFET amplifier module
