we all know that M2 is made to RuleThem All
You should really hear the MoFo, if you haven't. I'm listening to both right now.
Not at the same time of course.
Well, I'm a sissy trying to work out how to unsolder one of the jensens from the daughterboard it's in after my F6 met an untimely end... Any tips? This sissy needs a solution!
Edit: one of teabags ones GB for F6 Convertible Clone boards and to be clear the only issue with the build was the builder...![rolllaugh :rofl: :rofl:](https://files.diyaudio.com/forums/images/smilies/rolllaugh.gif)
solder sucker and solder wick , plenty of luck , work fast (shortest time possible per pin/cycle)
use fat tip , only way for fast heat transfer
be gentle with tweezers , when wiggling pin in hole
only when you free up all pins with wiggling - try to pull xformer out
Use flux on the joints when you desolder,even when using a solder sucker.Its messy but works better than a dry joint.
Use flux...
![up :up: :up:](https://files.diyaudio.com/forums/images/smilies/up.gif)
You can also use low melt or low temp de-solder wire, flood the joints with it, it'll stay liquid longer.
"Well, I'm a sissy trying to work out how to unsolder one of the jensens from the daughterboard it's in after my F6 met an untimely end... Any tips? This sissy needs a solution!"
Where in Sydney are you? I've got a vacuum desoldering gun. I can get it off the board for you.
Rick
Rick
- FirstWatt J2
