One direction sounds better than the other.
Can you give more info please? Where do you find info about different material permeabilities. Anyway it's much better than bare wire, there won't be air circulating inside the tube.
My personal DIY cable uses no tubing nor paraffin, it's put into bare cotton. Personally I do not fear surface oxidation and there is always some of it on every copper cable. Every plastic material leaks in air and any cable is prone to oxidize with time. My interconnects are two years old, have no visible layers of oxidation and sound fantastic. It's very important not to touch the copper with hands though. I always work with gloves.
The return is the same as the primary (20AWG) although it's better for it to be thicker and I can arrange that. Going to 18AWG for the Return will increase the cost with 6 USD.
Depending on your system and sound signature you want, I can suggest and install different RCA connectors. The stock ones are a bit on the calm side.
Why?One direction sounds better than the other.
Mike
Is this thread congregating cable virgins from throughout the world? Never head of wire directionality? First time now? Seriously?
Does this mean the virgins have already embraced the idea that wire sounds differently and just have trouble with directions? If so, this is real progress
So what happens if both wires have the writing in the same direction ?
rgds, sreten.
The sound is subjectively inferior.
Why?
Mike
Because I hear it so. And not only me. Three people (two of them females) near my system have approved it too, without knowing what was going on, but their description of the effect matched mine.
If you ask me for scientific explanation or measurements, I have none.
cable virgins...
Nice description.
FWIW, I've built IC's, and heard a directional difference.
This was a while ago, and for these cables, I thought it was more personal preference when deciding which direction to pick, but I did hear a difference. But I did like them better in a certain direction
And these do look like nice cables for the money
Nice description.
If you ask me for scientific explanation or measurements, I have none.[/QUOTE
In other words...JUST BELIEVE! HAVE FAITH! We don't need no steenkin evidence.
Mike
Mike
Yeah, why should I trust my ears??
You shouldn't trust your ears when other biases influence what you "hear." I've posted this link here before, but I think it does a good job of illustrating expectation bias. https://www.youtube.com/watch?v=G-lN8vWm3m0
Mike
nige2000.
I can also offer you a custom choice of RCA terminals, which influence the sound at least by 40%.Of course, the cost will alter, I can also build a custom cable with your personal connectors if you send them to me. You can choose from here:
EOS Electronics | Hi-Fi & Hi-End Audio | RCA Plug & Jack
With the original RCA connectors, the price is the same of course.
The shipment to Ireland is 7 euros. It's the slightly more expensive option, because it has insurance and faster delivery times.
The cable cost is 59 USD until the end of 2015
Hello,
It depends of your budget. The gold plating will "round" a bit, giving the feel of more body and gentle sound, but it removes from speed and attack IMHO.
The RP-190ST is silver plated, but it costs a bit more than the double of RP180GT.
The total cost with RP-190ST will be 86 USD including the X-mass discount.
My personal cable uses RP-190RT rhodium and I love it, but it costs 101 USD.
Hello,
right
will try to make it simple
can u price these two options in euro incl delivery
RP-190RT + RJ-133RT + cable
RP-190ST + RJ-133ST + cable
right
(RP-190RT + RJ-133RT + cable) I assume:
4 pcs of RP 190RT - 44 EUR
4 pcs of RJ-133RT - 16 EUR
cable cost without the connectors 39 EUR
Total: 99 EUR
(RP-190ST + RJ-133ST + cable)
4 pcs of RP 190ST - 30,40 EUR
4 pcs of RJ 133ST - 12,20 EUR
Total: 81,6 EUR
Regards,
Alexander.
Total: 99 EUR
Total: 81,6 EUR
Regards,
Alexander.
you got pm
How much will the cable cost go up after the sale is over?
TIA
Randy
69 USD
Regards,
Alexander
- Vendor's Bazaar
- FS: UPOCC copper handmade RCA cable
