Signup for relector ps board and kit
moorebj
Please sign me for 2 kits and boards MikeThis is a GB for Salas Reflektor-D and Reflektor-Mini Power supply.
This is a Low Voltage supply designed specifically for digital.
3.3V to 7V at 600mA max output using board level sinks.
Schematic and build info in PDF attachment at the bottom of post.
In the words of Salas -
The Reflektor concept is a shunt voltage regulator made around a current mirror circuit. To keep equal current between its input and output legs, the mirror reacts to flow disturbances and drives a MOSFET in opposite direction. A current loop simple regulator is another way to describe it. Specifically Reflektor-D is a version focusing on the voltage region common for powering digital source projects. For convenient mounting and setting it utilizes board level sinks and simple ways to choose its current limit and voltage output levels
The board is offered in a Matte Black 2MM thick PCB with 2 OZ copper. The cost is $16.00 plus shipping.
It was a very easy build, it took me 45 minutes to complete and then start testing, and got near target voltages rather easily via the LED swaps.
Three different kits will be offered. A transistor kit, a resistor kit, and a full kit, which includes all parts for board except standoff parts and MOSFET bolts and nuts for the heatsink.
The Reflektor-Mini was created to be installed into some tight spots. It is a much smaller board that will require its MOSFETS to be chassis mounted and electrically isolated for sinking. It keeps a lower height profile too. It is DC input only, needs an incoming DC feed.
It uses a J2 2SK117GR to stabilize and tune output voltage. For keeping small size It has a conventional 2Pin output. It's a slightly more complicated build than the original in some aspects and simpler in some other, but will serve it purposes in being a potentially lower cost unit to construct, as well as a smaller footprint.
In conjunction with the Mini release, the DC Flexy board is introduced. It allows for use of industry standard Snap-in Elcos or 4 pin/pole Mundrorf M-Lytic AG+. These boards can be used as Raw DC units to front end the power supply for the Reflektor-D Mini. They come in a breakable pair so to be used in double mono or multi isolated configurations of more than one regulator to feed. if used in a system of one regulator only, the spare may be broken off and kept aside since it can be utilized in a variety of projects needing Raw DC. Even for the standard Reflektor-D when done in its DC input mode version.
The signup for the boards is in my signature.
moorebj
The IRF9610 is a 6.4 C/W RthJC MOSFET. You would not want more than 100C at its core in the long run for reliability. Assuming 5-10V VDS across it. You could try a FAIRCHILD FQP3P20-ND for more than 1A constant which is still fast but has 2.4 C/W junction to case thermal. Spec is absolute max constant -1.77A at TC=100C. Still check with the oscilloscope that the output rail is oscillation free. Because it has more Ciss than the 9610 but not that much, +80pF. Just to make sure all is well. The output MOSFET wouldn't worry, its strong enough and its partially unloaded by the current sent to the powered client circuit.
A little bit late or earlyGB 2016#3 ? I need 2 mini/flexy boards + 2 xtransistor kit
Best regards, Erik.
These are still available. I will PM more info.
Kits received thank you ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
please could you explain with the 2SK117GR, you have included 2 pcs and one has been measured and marked. Is this measured one intended for J1 or J2 on the reflektor-d mini?
edit---- I guess it's the IDSS so it's for J1 to help determine the value of RR right?
thanks,
James
thanks,
James
is R-D for digital supply TDA1541A still available or need for next group buy?
These are still available. I will send a PM.
thanks,
James
Yes, The unmeasured is for use potentially as J2. In Reflektor-Mini, it is necessary.
Also, there are two diodes included 1N4148, and then a 1N5231B. They look almost identical.
If you use a diode tester, the 1N5231 will show more voltage across it. See the Reflektor-Mini build guide for further guidance to fine tune the output voltage. A little more work goes into implementation of the Reflektor-Mini.
The benefit is, besides footprint, is that with adequate heatsinking, you can really pump up the CCS and/or output current.
excellent, cheers. I have 1 working on the test bed now and all seems well.Yes, The unmeasured is for use potentially as J2. In Reflektor-Mini, it is necessary.
Thanks again,
James
- Group Buys
- GB for Salas Reflektor-D Power Supply for Digital
