Good 12-inch Woofer for OB?
It seems there are plenty of choices for 10 and 15-inch bass drivers for OB. But I am not seeing many 12-inch.
Is this as simple as finding a high efficiency (> 90 dB) and Qts > .6 that fits my price range or does Xmax also fit into the requirements?
TIA
Low cost chinese PA drivers seem to be good candidates as their diminute magnet sizes allow corresponding highish Qts... Like the unit that fitted my grandma's valve radio, 50 years ago, though that one was made at home sweet home, made great again tomorrow, or not...😛
Probably had a desireable alnico magnet too 😉 http://gr-research.com/sw-12-16fr.aspx
What a pleasant coincidence since I have been pondering the same question.
My plan is to put two on each side in a flat baffle paired with the
Tangband w8-1772.
I have been looking at the Visaton W 300. Om paper it looks quite promising from a quite well known brand.
Here in Europe you can get it for around 65 dollars. PE sells it for 80.
Might be worth it even in the US.
Looking forward to some valuable input in this thread.
/Majorna
I'm using 2 GRS 12PF woofers (PE 292-412 paper cone, not the sub version) in a Z-Frame and it sounds really good. It gets quite low too. See my crappy graph - I'm still new to HOLM. The magenta is near field.
