Yes, the Aune Mini Ape player will shuffle. In order to do so, it has to read through the entire directory before it will play. Takes about two minutes with the half a terabyte I have so far on my hard disk.
Anybody know what the issues are with using hard drives at below freezing temperatures?
--Buckapound
--Buckapound
The Aune sounds/looks very interesting for a car application. One question, can you set it to shuffle through the songs? Apparently the similar QA-350 player has this option.
Hello , The newest version of the mini APE is the Aune 32bit S1 HIFI music player , the information please check this :
32 BIT S1 HIFI Digital Music Player
http://http://shop2.hifidiy.net/index.php?main_page=product_info&cPath=10_33&products_id=111
The S1 player is not only a HIFI Music Player , it also can be used as :
•High quality 32BIT/24BIT/16BIT DAC
•High quality digital transport
•High quality headphone amplifier
![2-0.jpg](https://pic.hifidiy.net/images/MJ/S1/2-0.jpg)
![_MG_7737fsf.jpg](https://pic.hifidiy.net/images/MJ/S1/_MG_7737fsf.jpg)
Highlights
1) Use High quality TI CPU
2) Support 24bit/192K and 32bit music playback
3) With the SD card, USB flash disk as storage medium
4) USB 2.0 OTG ,ESATA , SD Card socket
5) With headphone socket
6) Support APE / FLAC / TTA / Mp3/ WAV/ CUE
7) Remote control Function
6) Support software Upgrade
7) With Network socket , support LAN connection
8) External five core power socket , with power upgrade function
9)AKM4390 DAC inside , support 32BIT
10) One way coaxial output and one way optical digital output
•Main functions
• USB2.0-OTG
USB 2.0 high –speed jack
• eSATA 3gb/s
eSATA high –speed expansion card
• 32BIT High Resolution
Capable of decoding 32BIT digital signal
• HIFI Quality Sound
Designed for HIFI quality sound reproduction
• Multifunction
Multifunctional used with PC audio , home audio and room audio devices
UNPACK
• 32 bit S1 HIFI Digital Music Player
Five Core Cable
External Power Unit
AC power Core
Remote Control
User manual
Specification
Frequency response :20-20KHz + - 0.2db
Distortion : 1KHz,2.8Vrms,-90db
Resolution : 106db
0dB output level (Line out )2.8VRMS
SNR(S/N):108db
Headphone amp power at 600 ohm : 2.8VRMS/13mW。
32ohm power :180mW
Dimension (chassis) :160*160*48(mm)
