headphone jack for single ended amp
im looking for a circuit that uses a dpdt switch to alternate between speaker out and headphone out. i understand i need to make a resistor network to make the output transformer see 8 ohms but im unsure of the resistor values for a 3 watt amp. also do i need an l pad?
LPad calculator here:
https://robrobinette.com/HeadphoneResistorNetworkCalculator.htm
You could rig up a 3 position rotary switch rotary switch for 32 ohm phones, 300 ohm phones, or speakers to select between lo/high lpad resistors or none for speakers. If you get a multi-deck multi-pole rotary switch you can double up the contacts for each channel to improve the reliability of the switch, more contact surface area. Just saying cheap switches are going to be the weakest link so get a good switch.
Reactions: redride27
something like this or this. The 2 have completely different resistance values achieving the same goal. Since my amp is only 4 watts are the 100 ohm resistors in the second picture overkill? upload_2021-9-8_11-5-22.gifPXL_20230101_205051213.MP.jpg
What kind of 4 Watt amplifier is this? If it's a SET without loop feedback, it can be operated safely without a heavy (8 Ohm) load, especially if you incorporate an output Zobel. This could be series'd 10R plus 0u1F, connected across the output transformer's secondary.
So, padding for the headphone output doesn't need to show the amplifier 8 Ohms. Several hundred Ohms is just fine, and allows you to leave the headphone jack live at all times. Only the speakers need be switched, and only on and off. Commercial amplifiers have been built this way since the dawn of time.
All good fortune,
Chris
That includes an output Zobel (drawn "above" the output transformer) and is marked as stable unloaded, so should be safe to operate with just a 2-pole single throw switch to the speakers, and a higher impedance (maybe a couple hundred Ohms pad to the headphones.
All good fortune,
Chris
Im torn between 2 circuits suggested by a few fellow DIYers. My knowledge is rather limited (l-pad and amplifier attenuation) so I'm hoping a few experts might chime in to explain the difference between the drawings. I'm currently designing the circuit layout) and im at the point of adding a headphone jack for the build.
its just a simple SET amp with about 4-5 watts of power. The problem is that my father wants the headphone jack to listen with his 5k $ focal utopia headphones (85 ohm impedance) that are for sure going to reveal any signal put out by my amp, good and bad.
Chris, the design does have local feedback
edit- wire wound vs metal oxide. Im having trouble sourcing non inductive wire wound resistors.
