Just a quick search on ebay and i found lots and lots of 2200uf 100v. Did not find exactly the right dimensions but you will probably find the one you need if you search for a bit 🙂
I did search for a bit, or I wouldn't of asked on here. And yes I can find a ton of 2200 100v but unfortunately they have to be that dimension. This was Last resort, but ok thanks a lot. Not sure why you would think I didn't check all other places, not trying to get a hand out of help without looking hard myself.
Thats unfortunate 🙁 there is alot of 2200uF 100v that is 30x30mm. What make and model are the caps?
Hi again kevamor.
These seem to be 25x30 but you have to ask the seller because it says 25x30mm and 30x30mm
10x Electrolytic Capacitors Condensateurs Électrolytiques 2200uF 100V Radial | eBay
Going over to Mouser, setting the diameter to 25mm or lower, the minimum height shown is 35mm. There may be somewhat unscrupulous individuals willing to sell you a lower rated voltage part which fits your dimensions, so caveat emptor.
Thank you so much man! Those ones you showed me on ebay that we weren't sure of the size, well they messaged me back and they were the size I needed, 25mmx30mm.
Since this is something that I may need at some point, I did some research and could not find that United Chemi Con ever produced a KMH series cap with those specs and size. Also, the 85c caps have black sleeves and the 105c caps have brown sleeves. The exceptions seem to be 'audio' caps with blue sleeves.
- General Interest
- Car Audio
- Help finding 2200UF 100V 105° 25X30MM capacitors
