Help finding 2200UF 100V 105° 25X30MM capacitors
I did search for a bit, or I wouldn't of asked on here. And yes I can find a ton of 2200 100v but unfortunately they have to be that dimension. This was Last resort, but ok thanks a lot. Not sure why you would think I didn't check all other places, not trying to get a hand out of help without looking hard myself.
Going over to Mouser, setting the diameter to 25mm or lower, the minimum height shown is 35mm. There may be somewhat unscrupulous individuals willing to sell you a lower rated voltage part which fits your dimensions, so caveat emptor.
Since this is something that I may need at some point, I did some research and could not find that United Chemi Con ever produced a KMH series cap with those specs and size. Also, the 85c caps have black sleeves and the 105c caps have brown sleeves. The exceptions seem to be 'audio' caps with blue sleeves.
