Alright Mooly will do! The Volume pot is 2x would there be a top pin for each gang? I didn't take the pot apart as I had stated I would do back a few posts. I just sprayed some more DeOxit into and tried to clean it a little more. Thanks Mooly
Yes, each gang is shown as having four pins, the fourth being for the loudness tapping.
Normally the signal feeds into one of the end pins (top pin as I call it) and the other end pin is ground. The wiper is the middle pin... but you have four pins... so you will have to figure the configuration out visually.
