I have one problem with my Marantz cd-62.
I dismantled the PCBs of my CD player, and when I mounted it again, did not function.
When I introduce the CD, the transport´s motor a moment functions and stops again , but it not recognizes the CD.
I thank your answers.
Sorry, my English is really poor
What have you done when you dismanteled the PCBs? Some maintenance, repair, modifications?
What is displayed on the display?
Are you sure you plugged the connectors correctly, and did not forget one?
I have dismanteled the PCBs, with the intencion to see the circuits of the PCBs to do future modifications.
In the display appears 00 00:00, if you push the play, the motor of the transport plays a moment and the lens does a small movement, but it does not recognize the CD.
I think I plugged the connectors correctly, I have done it several times. I have also dismantled the transport, It is possible that have it mismatched? or Or that have itself broken the ribbon cable?
Many thanks.
Many thanks.
Sorry
I have given me account, that the laser does not function.
Any suggestion is well received.
Greetings,
Cosme.
Greetings,
Cosme.
Luanak said:Sorry
Greetings,
Cosme.
Thats about the worst thing that could happen to your cdp!!!
Check your laser by looking at it with no cd inserted. Not directly, but at an slight angle (so you don't hurt your eyes). If you see a red glow from the lens it should be ok.
If you are lucky, only the adjustments are messed up.
- Digital Source
- HELP with a Marantz cd-62
